Something is wrong with the beast
Old May 14, 2006 | 06:50 PM
RunRed's Avatar
RunRed
Well today it finally happened, the beast did not start and I ran the batteries down trying. I don't know what is wrong with it. It smokes white when I am starting it and I do have blowby. My head gasket is blown (i think), it starts like crap and has barely any power. Suggestions?
Old May 14, 2006 | 08:36 PM
dieself250's Avatar
dieself250
We need more info , truck year,engine size ,trans, how much smoke? what leads you to think the head gasket is blown?
Old May 14, 2006 | 10:46 PM
RunRed's Avatar
RunRed
1990 7.3l IDI NA e4od Smokes just a little bit of thick white smoke while I am cranking over on it. I think the head gasket is blown because it leaks oil and I have replaced the valve cover gaskets and did the oil pan gasket twice just to make sure and I always had the same amount of oil leaking so that is why I think it must be the head gasket since they seem to go all the time.
Old May 14, 2006 | 11:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What does the smoke smell like?
Coolant will have a very sweet smell to it.
Are you losing coolant?
Do you have any in the oil?
Is there oil in the coolant?
Do you see any coolant laying on the rear of the intake manifold?
Old May 15, 2006 | 07:28 AM
RunRed's Avatar
RunRed
I do not see any coolant leak. My radiator is always at the same lever and it is always green.
Old May 15, 2006 | 03:58 PM
dieself250's Avatar
dieself250
Does the smoke smell like fuel? I bet you have a few bad glowplugs , eazy test, take a 12v test light, clip one lead to the positave post and tuch the top the each plug with the other end, remove the wire from the glow plug first. if it lights the plug is good, no light bad plug, replace only with motorcraft DZ9.
can you pinpont were the oil is leaking from? top or bottom back or frount? it might be best to degrease the entire engine and then run it for a bit and see if you can spot the sorce
Old May 15, 2006 | 05:35 PM
RunRed's Avatar
RunRed
I've tested all the glow plugs and the relay and they are all working fine. I am not sure where the leak is, more like above the starter. The wind bathes everything in oil, hence my truck has minimal rust.
Old May 15, 2006 | 09:45 PM
Dave Sponaugle
Could be two things that I can think of right now.
How long since the CDR was serviced?
It should be soaked and then rinsed out with gasoline every other oil change.
It will get gunked up inside and not close under high vacuum which causes oil to get sucked into the intake. Do you see oil laying down in the intake manifold?
Or you could have an injector that is leaking fuel or not spraying properly which will cause white smoke from unburnt fuel.
Since you are having oil consumption, it is probably the CDR.
Blown head gasket does not sound right because there is no oil pressure passages that go through the head gasket. Just drains back to the oil pan.
With the engine idling if you had a blown head gasket you should be able to see a compression leak from under the truck. Also a blown head gasket will usually involve the coolant passages in some way.
Old May 15, 2006 | 10:33 PM
RunRed's Avatar
RunRed
What is a CDR? I do not think it "uses" oil, it leaks it all out from somewhere, there is no oil to speak of above the maybe exhaust manifold.
Old May 15, 2006 | 11:33 PM
PLC7.3's Avatar
PLC7.3
The CDR is the tin pot behind the intake, use caution when removing as the tubes are very brittle after a long time. If the CDR is grey I would consider replacing it. If you see any black chunks in the intake or on the screen then it has disintegrated internally.
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A The part # for the rubber tube on the CDR... Retainer # E8TZ 6A892A
IH part #1805319C1 CDR
Check the Oil pressure sender on the back of the block, they are known to leak.
Old May 16, 2006 | 11:23 AM
81fordf-250's Avatar
81fordf-250
glow plugs
Glow plugs can short out and draw a lot of curent and not heat up. Its unlikely that they would all short out at the same time.
Old May 16, 2006 | 08:13 PM
RunRed's Avatar
RunRed
Well the oil is everywhere from the front of the engine running all the way to the end of the transmission. I am sure a lot of it is run off oil, I am just saying it isn't just rear of the engine or something, it is most heavily noted around the exhaust manifolds towards the rear of the engine.
1986Beast
May 3, 2012 02:50 AM
The79Beast
May 20, 2011 12:53 PM
helifixer
Arizona Chapter
50
Feb 17, 2009 11:54 PM
5_labsownus
West Virginia Chapter
Mar 10, 2007 09:54 PM
Beastmaster
Aug 14, 2005 05:04 PM
