Sponsored by: Real Truck
No trailer lights
Old Dec 15, 2015 | 08:27 AM
Duck410's Avatar
Duck410
No trailer lights
12 F250 6.7 supercab 4x4 no power to trailer connection at the back of the truck fuses are good any ideas this is the bosses truck
Old Dec 15, 2015 | 08:39 AM
wrvond's Avatar
wrvond
How did you test for power at the connector?
Did you try plugging the trailer into a different truck?
When you plug it in, does the information display show a trailer connected?
Old Dec 15, 2015 | 07:11 PM
2001F350dualwheel's Avatar
2001F350dualwheel
First I would check ground to the trailer from the truck. Then check for power on your truck connection.
Old Dec 15, 2015 | 08:25 PM
senix's Avatar
senix
Usually the first place to start after checking all fuses is the 7 pin connection at the back of the truck. Take the plug apart and check for dirt, corrosion and loose connections.
Second place is the trailer connection as well.
Old Dec 15, 2015 | 08:41 PM
r2millers's Avatar
r2millers
Do you check the dedicated fuses for the trailer, under the hood. Could be some confusion here as you have two sets.
If they're blown, probably a dead short, grounding to the frame.
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
kyle41
2009 - 2014 F150
Jul 12, 2017 05:26 PM
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
jonrjen
Electrical Systems/Wiring
Feb 17, 2015 03:55 PM
3505740
Jul 12, 2013 01:57 PM
