1979 dash removal
Old Dec 15, 2015 | 08:16 AM
460harris's Avatar
460harris
1979 dash removal
I'm in the process of taking my 79 for truck down to bare metal and was wondering if anyone had taken the complete dash off. I've looked and it appears that I only found 5 bolts.does that sound right? I have everything else off already. Dash pad is off the heater controls are off trim pieces.
Old Dec 15, 2015 | 08:30 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Look at the far left and right upper edge, right where the dash meets the top part of the kick panel. There might be a bonded or just sealant on it metal tab there on each side?
Instrument cluster? Defrost vent, center speaker wiring, steering column bracket, the long wiring harness going side to side in the plastic black tube that is slit down the side?
Old Dec 15, 2015 | 09:12 PM
460harris's Avatar
460harris
Got it removed. Not that big of a deal.
Old Dec 15, 2015 | 10:14 PM
77&79F250's Avatar
77&79F250
I am sure you can figure out the vents and the vent outer piece, careful the mount tabs break easily.
Old Jan 3, 2022 | 09:41 AM
77F100Vic's Avatar
77F100Vic
I also need the complete dash removed. Do you remember how many bolt are there and their locations?
Thanks.
Old Jan 3, 2022 | 10:27 AM
77&79F250's Avatar
77&79F250
460harris last visit to FTE was 08-24-2016....
Old Jan 3, 2022 | 10:34 AM
Peter Gozintite's Avatar
Peter Gozintite
Thanks.
There are a bunch of screws along the top of the dash pad, facing upward toward the windshield. Then there are 5 bolts, I think. One at either side of the cab, two in the steering column support, and one in the E-Brake mount. I had mine out for paint not too long ago.
Old Jan 3, 2022 | 10:53 AM
77F100Vic's Avatar
77F100Vic
Thanks everyone! I'll give it a try today.
Old Jan 3, 2022 | 11:22 AM
440 sixpack's Avatar
440 sixpack
It's a lot easier than you'd expect.
Old Jan 3, 2022 | 12:26 PM
Citymorg's Avatar
Citymorg
That looks kind of like mine. I took the dash out to install A/C decided to paint it to match the truck instead of the black that it was.
abosely
Dec 6, 2015 05:04 PM
86Stepside
Oct 4, 2013 10:22 PM
Phy
Jul 7, 2011 01:31 PM
mpgvan
1983 - 2012 Ranger & B-Series
May 28, 2009 03:46 PM
laptopgeek
Apr 10, 2003 10:03 AM
