advice taking plastic dash apart
Old May 26, 2009 | 08:27 PM
mpgvan's Avatar
mpgvan
i am working on a a friends 1991 ford ranger.. i need to pull the dash apart to get at the wiring.. when i looked at the dash i didn`t see any screws, so i assume it is held on with clips or some kind of fasteners... i am afraid to just start prying on the cheap plastic in fear of cracking it... please help with instructions i need to get his truck fixed and back to him ASAP
Old May 26, 2009 | 10:44 PM
g_k50's Avatar
g_k50
How do you know that you need to take the dash apart to get to the wiring? I'm wondering how you know about wiring but don't know about how the dash is attached in a 1991 Ford Ranger.
Old May 27, 2009 | 06:20 AM
LMS Residential's Avatar
LMS Residential
Get yourself an inexpensive set of pry tools and picks (about 8 bucks) at an Auto zone or similar discount parts place. Most of the dash pieces (in my 97 anyway) usually have a couple of small hex bolts at the bottom with clips up the sides or on the top. Start at the bottom and work up. Removing the panels in sequence exposes the hidden fasteners at the bottom of the next panel and so forth. Downloading radio removal detailed instructions from a car audio forum might help get up the center of the dash.
Curious as to what you need to get at??? Post more specifically and you'll probably get better answers.
Old May 27, 2009 | 11:12 AM
michigan66's Avatar
michigan66
You need to remove the ash tray and then remove the screws that retain the tray holder. After that, the trim piece that surrounds the ash tray, radio, vents and the lower part of the panel will snap out. There are seven snap-in retainers. Pull gently.
If you want to pull out the instrument cluster, disconnect the PRNDL cable from the steering column (if you have an automatic trans.) and then remove the four screws that retain the cluster. Pull it out far enough to disconnect the speedometer and unplug the wiring connectors.
Good luck.
Old May 27, 2009 | 09:21 PM
Traxxis's Avatar
Traxxis
Good call Michigan... that's pretty much exactly what I was going to tell him.
I think some reputation points are in order...
Stan
Old May 28, 2009 | 06:39 AM
mpgvan's Avatar
mpgvan
this is a work truck with a large light bar. i need to test the switches that have been installed in the dash under the light switch. . .. i have linked a photo.. this is my first time posting a pic so i dont know if the link will work....
Old May 28, 2009 | 10:59 AM
g_k50's Avatar
g_k50
The switches should pry out from the front, no need to take the dash off. Test the switches with a Volt-Ohm-Meter VOM, cost about 10 at walmart. Set the VOM to Ohms, that's resistance (donchaknow). When the switch is on resistance should be zero, when the switch is off the resistance should be infinity, that's a lazy 8.
Old May 28, 2009 | 03:46 PM
michigan66's Avatar
michigan66
Hi mpgvan,
You will have to remove the instrument panel trim to get to the panel that has the switches.
cabloom300
1997 - 2003 F150
Jan 6, 2011 05:40 PM
Aaron-71
Sep 1, 2010 01:18 PM
Subzero870
Mar 16, 2009 06:17 PM
tuono
Appearance & Dress-Up
Nov 8, 2004 04:05 PM
canucker
1997 - 2003 F150
Aug 14, 2004 07:57 AM
