Y'all have been a tremendous help so far and have taught me tons. I'm about to set a rebuilt engine and I don't know how to set the height of the oil pump pick up to ensure proper oil flow from the bottom of the pan. Anyone know how to do this?
Agreed....if you can see the screen through the drain hole, about 5/16" - 3/8" off the pan bottom, you're gold. Don't forget that the little washer dealie on one end of the hexagonal pump drive goes toward the top of the engine.
I usually mock assemble by putting a piece of paper over the screen and some play dough on top of that then install pan and then remove and measure the squish
