PARKING LIGHT PROBLEM 2000 Ecursion
Old Dec 13, 2015 | 10:37 PM
towman2you's Avatar
towman2you
Question PARKING LIGHT PROBLEM 2000 Ecursion
Ok, I've read another post with the same issue, but it was caused by the alarm. My issue is my parking lights or dash lights won't turn off. I just got the truck about a month ago, and was going through and fixing auxillary plugs and replacing fuses. I replaced blown fuse #4 (trailer tow Backup lamps, trailer tow park lamps) in the power distribution box under the hood and the issue arose. No trailer hooked up, and havent messed with the plug. also, I don't think the brake controller is working either.
Old Dec 15, 2015 | 05:49 AM
Franklin2's Avatar
Franklin2
Pull the fuse just to verify the problem goes away. If it does, you know what is powering the circuit when it's not supposed to.
I would then find a major looking plug or plugs in the rear bumper area and unplug them. See if the problem goes away with the fuse in place. If it does, you know the problem is back there somewhere.
Old Dec 15, 2015 | 01:08 PM
towman2you's Avatar
towman2you
Thanks I'll look at that, and yes the problem goes away when I pull the fuse.
2horses
6.7L Power Stroke Diesel
15
Oct 30, 2011 04:00 PM
odiemallard
Electrical Systems/Wiring
May 30, 2008 08:12 AM
BuCKxWiLD
Jul 12, 2005 07:00 PM
wat704
1997 - 2003 F150
Mar 1, 2005 10:16 PM
Hburger
Oct 12, 2004 08:06 AM
