Cranks but doesn't start
Old Dec 13, 2015 | 10:15 PM
1984_IH6.9_Project's Avatar
1984_IH6.9_Project
I got a 1984 f-250 6.9L IDI... It had been sitting since 07 until I got the rear axel on it and me and my dad drove it to his house... It doesn't want to start now all it does is crank but not start... It was driven to where it was parked in 07 and my great grandparents used it as a daily driver until then... Any ideas on what the problem is and how I could fix it... It tries to start better now that I changed the o-rings on the two leaking injectors
Old Dec 13, 2015 | 11:20 PM
AKHunter93's Avatar
AKHunter93
These diesels need a few things to start. Fuel, air, compression.
I don't know where you're at, but if you're in a cold climate with this problem, my first inclination would be the glow plugs and/or the relay. I assume you've already verified your batteries and starter are good. If it's cranking slowly, then the batteries and/or starter may be to blame.
Next, check for fuel. Verify there's fuel in the filter. If there is, move on down the line. Crack the injectors and ensure that there's actually fuel being delivered to the combustion chamber.
If the truck sat for a long time, it's possible that something corroded enough that it was able to develop a leak once you started it up, that is no longer permitting it to start.
Just my thoughts. I'm still learning about these IDI's myself, so I'm certain there are simple things that I haven't mentioned.
Old Dec 13, 2015 | 11:37 PM
1984_IH6.9_Project
I put new batteries in it and fixed the injector leaks (with new lines and o-rings) I haven't found a leak... It cranks fast and tries but it just won't go
Old Dec 13, 2015 | 11:48 PM
AKHunter93's Avatar
AKHunter93
Well if you know that it's cranking as it should and you're getting fuel through all of the injectors, that only leaves a lack of air or lack of compression. Is your air cleaner or intake blocked somehow?
On the compression side, your rings could be shot, head gaskets could be shot, worst case scenario would be a cracked head or block, though I doubt it.
Are you trying to start it in the cold? Have you verified that the glow plugs are in good working order?
Old Dec 14, 2015 | 01:15 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Any smoke while cranking? If its white, glow plugs likely arent working. No smoke = no fuel.
Old Dec 14, 2015 | 12:16 PM
1984_IH6.9_Project
Little smoke but it's dark grey/black
Old Dec 14, 2015 | 12:17 PM
1984_IH6.9_Project
Either glow plugs of fuel filter is shot... I might be putting the new fuel filter on today... Would it help if I replaced the stock with a cold air
Old Dec 14, 2015 | 03:01 PM
mebe2k's Avatar
mebe2k
if it has a manual trans, hook a tow strap up to it, put it in 2nd or 3rd gear, pull it with another truck, and pop the clutch.. that is how I got mine to run..the starter just wasn't turning it over fast enough..that and the low compression wasn't helping it either..
Old Dec 14, 2015 | 03:13 PM
AKHunter93's Avatar
AKHunter93
Black smoke isn't a bad glow plug. Bad glow plugs will cause unburnt fuel to be sent through the exhaust, which is white smoke with a bitter smell.
A bad fuel filter is easy to check, pop it off and look at it. There's no such thing as a "cold air" fuel filter. Do you mean replace your exhaust air filter?
Old Dec 14, 2015 | 09:17 PM
1984_IH6.9_Project
Got a new fuel filter in it tonight and it starts perfectly every time
Old Dec 15, 2015 | 08:37 PM
1984_IH6.9_Project
Now it's not wanting to start again today... Any other help for that?
Old Dec 15, 2015 | 09:19 PM
southern-old-bold's Avatar
southern-old-bold
square #1
Ok. Go back to the previous advice on glow plugs and air intrusion, cranking speed, that and the stickies at the top of the forum will help you out. It's just a matter of being thorough with everything.
Old Dec 16, 2015 | 09:00 AM
1984_IH6.9_Project
There might be some air in the lines still... I will hopefully have the tools to check the glow plugs soon... I have 2 weeks to get it running good then I have less time because of school
Old Dec 16, 2015 | 09:34 PM
1984_IH6.9_Project
I think part of the problem is that today my dad burnt up the starter solenoid
Old Dec 17, 2015 | 11:18 AM
AKHunter93's Avatar
AKHunter93
A weak starter will cause a no-start situation even with everything else running perfectly. You shouldn't have introduced any air to the system by replacing the filter, and even if there was air, it would work its way out as you turn the engine over. You have to remember not to run the starter continuously though, because that will fry it.
pick1
26
Nov 20, 2024 10:13 PM
Crazyhorse120
Oct 14, 2012 02:28 PM
kowalski22
Feb 28, 2012 06:41 PM
madriver
Apr 12, 2008 04:39 PM
MasterTrim
Dec 3, 2004 06:46 AM
