Sponsored by: Real Truck
Death Wobble
Old Apr 2, 2017 | 05:44 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Got the new shocks put on today, but for some reason I managed to order the wrong steering stabilizer. Ordered one for 05-07 instead. Doesn't fit btw. So have to return it and order the correct one.
Took it for a short test drive, ride seems nicer in most cases, but rough expansion joints still seem the same as before. I was surprised how much longer the Bilstein's were than the original shocks.
Rears weren't too bad to put on, pretty straight forward and easy. The front's were a huge pain in the ***, upper bolts were badly rusted and took most of the day to get the front pair off. Won't need it again for a few years, and will definitely have a big hoss air compressor on hand to spin my impact wrenches. Instead of John Wayne'ing them off by hand with an open end wrench.
Old Apr 6, 2017 | 05:52 AM
Slowpoke Slim
Correct steering stabilizer arrived yesterday. Installed it last night. Made a huge difference during test drive over known problem roads that would start the death wobble. Drives like a new truck again. At least in my truck, replacing the stabilizer fixed my wobble issues.
Old Apr 6, 2017 | 05:55 AM
CollinsCD's Avatar
CollinsCD
Same thing for my truck. Removed the stock stabilizer and installed a Bilstein and my death wobble went away.
Old Apr 6, 2017 | 10:15 AM
Fordbronco1995's Avatar
Fordbronco1995
And in some cases i would install a dual steering stabilizer
Old Apr 26, 2017 | 06:58 PM
Jbsuperduty's Avatar
Jbsuperduty
Thumbs down More death wobbles
Three different days three different roads and the wobbles is still there, Dealer again says on my invoice " Concern is minimal" check out this video especially the third shake. How is this not a recallable item?
Old Apr 26, 2017 | 09:07 PM
Fordbronco1995
Theres no recall on it because replacing the factory components with new factory components isnt going to likely fix it. The problem is in the design, dodge is in the same boat. Put dual steering stabilizers on it and see if it goes away
Old Apr 27, 2017 | 07:01 AM
T diesel's Avatar
T diesel
Make a complaint here...
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Old Apr 27, 2017 | 01:54 PM
sur48's Avatar
sur48
[QUOTE=Fordbronco1995;17093227]And in some cases i would install a dual steering stabilizer
[/QUOue
Another item Ford should have installed Ford factory.
I installed this double stabilizer with 22.5 and stopped all wobble
dmen
Oct 25, 2011 06:40 PM
Ryan50hrl
2004 - 2008 F150
May 17, 2009 10:14 AM
BadHabitinVA
Oct 6, 2006 07:05 PM
Tptoe
Jan 22, 2004 12:00 AM
Big
Apr 3, 2003 07:11 PM
