I had my lower bj's replaced not too long ago (under warranty) and the shop used aftermarket parts that do have zerks. You'll know right away if yours have the fittings by looking underneath the front end.
Hate to cause trouble, but doesn't it seem unlikely that ALL those parts were worn at only 73,000 miles?
I have 67K on mine and was also concerned over the lack of grease fittings. Everything still seems very tight though. I guess I should have a "pro" check it, but it's got to be somebody who won't put a sales job on me!
I wouldn't be surprised if the upper control arms aren't unitized...as in you can't replace the upper ball joints alone--they're welded/riveted/somehow secured in the upper control arms. This would require upper ball joint and control arm replacement...and if you replace the control arm at 73K, you should replace the bushings as well. The lower ball joints were replaced by themselves, which I'd expect.
As for the tie rods/ends/etc., after the ball joint replacement they probably wanted to do an alignment and found some/most parts were seized up. Not all that uncommon...but they could've been ripping you.
As for having a "pro" check it, for the most part, 99% of ball joint and tie rod problems can be found with a simple test. Jack up one front wheel on the truck and grab the tire at the top and bottom. Shake vigorously. Any play? Now grab on the left and right side. Shake vigorously. Any play? If there is play, it is either in the control arm or A arm bushings, the ball joints, the tie rod ends, the wheel bearings, or (yikes) the studs/lug nuts holding the wheel on. If you find play, have someone else shake while you watch for movement.
Yeah...the FORD ball joints are a rip off and a joke...My wifes squeak like all hell, and the OEM FORD ball joints DO NOT have zerks to keep them greased up. Buy them aftermarket...they will last alot longer because you can grease them, and they are probably also made better than Fords ball joints.
