Sponsored by: Real Truck
Fuel pump relay
Old Dec 12, 2015 | 12:40 PM
96DRW's Avatar
96DRW
Fuel pump relay
Hi all - I have a 2000 F250 SD gasser. I want to replace the fuel pump relay. I removed the radio and took the relay panel cover off. There are three relays, one big blue one and two smaller (same size) black ones to the left of the blue one. In reading other posts I'm thinking the top small black one is the fuel pump relay. My question: is the relay supposed to come off just by pulling on it? I pulled on the relay and it seems lock on. I can wiggle it. I don't want to pull too hard. There is space for just one hand to grab the relay. The three are closely placed together which adds to the challenge. Any tips on disconnecting the relay? Thanks
Old Dec 21, 2015 | 02:01 PM
9rudy9's Avatar
9rudy9
I just held the connector and grabbed mine and wiggled it off yesterday. They are pretty tough Might be good to disconnect the battery. I pulled the blue one off first for fun. It is the turn signal relay I believe. Good luck.
Old Dec 22, 2015 | 05:38 PM
96DRW's Avatar
96DRW
Thanks for the reply. I got it off by wiggling it.
Old Jan 14, 2017 | 02:51 PM
SR71BLACKBIRD's Avatar
SR71BLACKBIRD
2002 F250 Super Duty V10 6.8L Relay Location
Relay is integrated in to fuse panel. Entire panel must be swapped out. Should cost $200-$300. Location was not in repair manuals. Ended up taking to a mechanic who ran an electrical diagnostic program.
bleevan
Aug 22, 2007 03:06 AM
Ionlydrivefordtrucks
Jul 23, 2007 08:59 PM
meck1
Electrical Systems/Wiring
Jun 4, 2007 02:42 PM
texasgoat
1978 - 1996 Big Bronco
Jan 7, 2005 06:45 PM
