2015 QUESTIONS
Old Feb 9, 2016 | 07:05 AM
Tom's Avatar
Tom
Originally Posted by mynetdude
I know this is about '15 or newer... but does the '14 have a different OLM computer? I seem to average roughly 5-7k between oil changes as the manual says I should do it every 7,500 IIRC... but it also has extended usage parameters which calls for more frequent changes at 5,000 instead.
I'm not sure I understand what you're asking. Unless you have the 6.2L V8 your owner's guide says the interval is what the OLM dictates. There is no published standard otherwise. What are extended usage parameters?
does the '14 and the '16 have different 3.5EB engines? BTW my truck just came in from the delivery point from the OEM so its at the dealer now... 2016 F150 Platinum FX4 SCREW
The 3.5L EcoBoost is unchanged, they are the same. The only revision I'm aware of is different CAC and mounting location, and people don't seem to be having issues with condensation.
Old Feb 9, 2016 | 11:52 AM
mynetdude's Avatar
mynetdude
So the OLM follows what the manual says? I still get stickers that says every 3,000 miles :P
What I mean is the OLM computes your oil life based on your driving; the more city driving you do the less oil life you're going to have vs highway or does it go through oil the same amount or same way no matter the driving conditions? (I'd imagine its worse for offroading as its filtering that dust).
When you look at your manual you'll see recommendations for normal use and extended/heavy usage, etc etc whatever I forget the term they use... but when you use the vehicle more than normally they have other recommendations.
I thought I read somewhere they had made some small changes to the 3.5L EB but I may have likely misunderstood what was being talked about. And I was totally unaware there were condensation issues.
but hey if the '14 and '16 have the same exact 3.5L EB that's good then I'll know what problems to look for (oh yeah I had a few problems myself on the '14).
Old Feb 9, 2016 | 04:32 PM
khadma's Avatar
khadma
Carpenter Local 745
"Extended parameters" I would interpret as added stress to the engine: dusty conditions, towing, stop and go traffic, heavy hauling.
As I recall, which ARE outlined in the owners manual.
With this said, I guess doing an early oil change will NOT hurt, right?
My thought process, from the engineers point of view, is that the engineers are trying to help reduce overall operating costs of the vehicle.
Me, being "old school" and changing my oil every 3000 miles, did find it hard to believe that running Motorcraft oil in this 2.7 for 10,000 miles is hard to
fathom. Itʻs the same oil we have been using for years. It must be newer engine materials that are making a difference.
Old Feb 9, 2016 | 06:12 PM
mynetdude's Avatar
mynetdude
I don't see why it would hurt, but why waste the money when knowingly it can operate for longer periods in between oil changes unless you're doing high/extended usage then I'd say 3-5k would be a good number to stick with (it still is regardless of what kind of usage, but unless you're doing nothing but highway/rural driving there's no need to use lower numbers I'd love it if I could get 10k before I need an oil change but I think that requires full synthetic which comes to my next dumb question:
I thought the newer engines were using synthetic anyway? I'm told 5w30 is regular oil (just like 10w30 but a different viscosity or whatever it is)
Is it really the same oil all these years? Its true the new engines are made with different materials, but with new materials comes new stuff in oils too I am sure (doesn't oiil have to meet EPA standards like gasoline does?)
Old Feb 9, 2016 | 07:27 PM
Tom's Avatar
Tom
It's most certainly NOT the same oils we have been using for years. The current spec, API SN, was introduced in October, 2011. The standard has changed eleven times since the API began certifying oils in the 1920s.
http://www.api.org/~/media/Files/Oil...0210.pdf?la=en
Old Feb 9, 2016 | 11:34 PM
JKBrad's Avatar
JKBrad
Like Tom said, it isn't the same at all. The API spec has changed several times in just the last decade. And the 5w30 spec'd for the EcoBoost is a semi-synthetic. Many conventional oils are near synthetic in quality under API SN.
Many synthetics are now made from gas to liquid (GTL) base stocks now, these oils are incredibly pure and durable. They are eclipsing the old preferred synthetic stock, PAO. Actually, it's difficult to find a bad oil these days.
Old Feb 9, 2016 | 11:42 PM
mynetdude's Avatar
mynetdude
how can it be pure if the oil is mixed with the real petroleum based oils? If it were pure wouldn't it be fully synthetic?
And wouldn't full synth be better than synth blend? Although a full synth for EB is almost $70, I remember oil for the 7.3L PSD was almost $100! (takes more oil to run that PSD than the EB obviously).
Does the OLM know the difference between synth blend and full synth? I would hope so since it has sensors to tell us when to change the oil
Old Feb 10, 2016 | 12:24 AM
JKBrad's Avatar
JKBrad
I said that many [I]synthetics[I] these days are made from GTL. Semi synthetic is a blend of conventional and synthetic.
The OLM functions on nothing more than algorithms based on input from the PCM. there is mo sensor testing the oil for contaminates. Think of the OLM as a general guideline. You can reset it yourself at anytime, kind of like the average MPG meter.
Old Feb 10, 2016 | 01:25 AM
mynetdude's Avatar
mynetdude
ah well what's the point of an OLM if its not going to do much? Since its not contaminant based (which I don't think it could ever be) I think the life of the oil is the same whether you are mostly highway vs city... you reach 5,000 miles a lot quicker on the highways than you do in the cities... so time is also a factor and will decrease the life of the oil according to the OLM.
Old Feb 10, 2016 | 05:24 AM
khadma's Avatar
khadma
Carpenter Local 745
Sorry everyone, I have been using SEMI BLEND Motorcraft oil for sometime now and to me it seems like years. I did not in no way mean that I have
been using the same oil I used in the 80s.
My comment was purely figurative. Sorry guys!
Old Feb 10, 2016 | 07:37 AM
Tom's Avatar
Tom
Sort of. The spec WSS-M2C946-A is met by every name-brand conventional oil I bothered to look up. Motorcraft is marketed as a semi-synthetic in the U.S., but conventional in Canada. If anyone finds a conventional 5w30 that's not certified to WSS-M2C946-A I'd love to know.
Yup. Just about anything with an API SN rating will do a great job.
The life of the oil varies dramatically based on driving conditions. Those who do lots of highway driving often find on their UOAs that they can stretch out their drain intervals well past 10,000 miles on conventional oil. On the other side, those who idle a lot and do lots of short trips couldn't go anywhere near as long. I believe this is the reason for the OLM, it takes into account operating conditions to provide an accurate estimate of oil life.
If you have an hour or so and want some light reading check out this article:
Motor Oil 101 - Bob is the Oil Guy - Bob is the Oil Guy
Bayer-Z28
Nov 24, 2009 06:43 AM
operator exmark
Jul 21, 2007 11:24 AM
Metro2
Dec 4, 2004 02:21 AM
Jud75
Jul 20, 2004 10:12 AM
christaylor
Oct 15, 2003 02:15 PM
