Changed transfer case now truck won't start
Old Dec 8, 2015 | 04:07 PM
Chrisweidow's Avatar
Chrisweidow
I changed the transfer case in my truck today and now it won't start. It's a 302 with a c6 and bw135 case. I have fuel and spark, so I'm at a loss. Any help would be appreciated. Thanks.
Old Dec 8, 2015 | 04:11 PM
Grems4ever's Avatar
Grems4ever
If it isn't cranking - check your neutral safety switch and/or transmission shift linkage. If it thinks its in gear it won't crank.
If it's cranking without starting, then I would check to see if you bumped the wiring for the fuel pump or something in the area you were working on. You might have accidentally disconnected something...
Old Dec 8, 2015 | 04:13 PM
Chrisweidow
It cranks and I have fuel. I am going to see if I bumped anything in the morning. The only thing I noticed was a whine from the starter relay when it is cranking that I never heard before.
Old Dec 9, 2015 | 06:06 AM
bashby's Avatar
bashby
Carb or EFI?
1989FordF250
Aug 20, 2017 01:13 PM
jhlowrider
May 13, 2014 07:34 PM
Marc150
Apr 22, 2004 10:32 PM
