1990 f150 5.0 timing,exhaust pop,3rd gear shake
Hi ladies and gents
new proud owner of a 1990 f150 5.0 with a few issues, the guy i bought if from said he replaced the computer and a couple other things but was hard to get a straight answer out of him on any of it. 1st what should the timing be set at on a 5.0? (guy said he was setting it by ear, if thats the case he needs a hearing aid) and engine has a shake at idle but smooths out when i give it some gas. 2nd i have a exhaust pop/backfire only when the engine is warmed up. 3rd is i have a shake after it goes into 3rd gear and it dont seam to go into OD or maybe its skipping 3rd gear all together? it looks to have new plugs,cap,rotor,wires. i changed the VSS because it was shifting hard and that did take away some of the hard shift between the gears but still seams a little hard to me. both exhaust manifolds are cracked and i went to change them and the very first bolt broke off so that is going to wait till spring when i wont need the truck so much, i would just like to get it running better to make it threw the winter, i kinda knew what i was getting into only paying 1400 for the truck but the inside and outside are clean ... any help would be nice thanks
wont do that again
well i finally had time to spend a day working on this truck, its funny how a engine runs great when ALL the spark plug wires are going to the right places ... the guy i brought if from changes all the sp wires cap and rotor, well he had the number 1 and 2 plug wires switched on the cap so both of them were firing but not when they were supposed to!!!! so i went from a 6 cylinder to a nice running 8 .... i will never NOT check someones work again just because they sound like they knew what they were talking about
ClassiccarJ
03-19-2018 07:44 AM
tractormanmike
16
12-06-2012 05:44 PM
67aj
03-02-2004 02:28 PM
cobra67
11-23-2003 09:57 PM
