300/4.9 6 into big block frame?
Old 12-07-2015, 01:51 PM
abosely's Avatar
abosely
abosely is offline
Will be putting a 300/4.9 6 into a 92'-96' F250/350 frame that had a big block or Diesel in it.
I'll be starting with a bare frame. Looking for clean frame so don't know which engine it will be set up for, but figure will be 351, 460 or diesel.
If I pull a 300/4.9 6 out of a 95' bronco, I should pull the engine cross member and swap it into the F250/350 frame and use 300 6 motor mounts, correct?
I don't want to leave the big motor cross member in the frame as it will be bigger than needed and in the way. Or is the cross member the same and engine mount are different?
Doing a D60 SAS & high steer so don't want anymore bulk in the way than needed.
Cheers, Allen
Old 12-09-2015, 03:36 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is online now
you shouldnt have to alter the crossmember what so ever. just get a set of engine towers from an F150 and should bolt right up.
Old 12-10-2015, 01:31 PM
abosely's Avatar
abosely
abosely is offline
Great thx. Are the rivet holes there? If not not a big deal to figure location for 300 6 mounts, but wondered. :-)
Cheers, Allen
Old 12-10-2015, 04:28 PM
Kemicalburns
i would think so, frame is basicly the same from cab forward.
Old 12-10-2015, 09:13 PM
abosely's Avatar
abosely
abosely is offline
Figured there probably were but if not isn't an issue. But I'll take all the help I can get to simplify locating the mounts.
Cheers, Allen
Old 12-11-2015, 10:37 AM
Kemicalburns
installing the D60 should also be bolt in.
thestinkyone
09-30-2018 01:28 PM
louisj
02-19-2017 07:47 PM
Randy Obrien
07-13-2014 07:27 PM
E30tdf
Engine Swaps
11-28-2008 10:26 AM
75f100
07-07-2003 12:30 AM
Quick Reply: 300/4.9 6 into big block frame?
