Towing help
Old Dec 7, 2015 | 03:51 PM
Tgar's Avatar
Tgar
What's wrong with towing a travel trailer with an f150 ecoboost
Old Dec 7, 2015 | 04:07 PM
RV_Tech's Avatar
RV_Tech
I don't think there is anything wrong with it. If my towable weights allowed it and I didn't need to buy another truck, that is what I would do.
The dually I have is overkill, but was purchased with another purpose in mind.
Steve
Old Dec 8, 2015 | 09:10 AM
wrvond's Avatar
wrvond
Nobody said there is anything wrong with it.
But since you asked, I'll tell you -
the F150 doesn't have nearly as much leg room as the F250.
There, I said it!
Old Dec 8, 2015 | 10:14 AM
RV_Tech's Avatar
RV_Tech
Well, there's something else I didn't know. The list just keeps getting longer!
Steve
Old Dec 27, 2015 | 03:54 PM
jack alley's Avatar
jack alley
I have a 07 Ford Expedition I am trying to toe a 29' camper having trouble with the truck driving like I am on ice ( very unsafe feeling ) don't want to go over 55 or 60. I have tried 2 different Equalizer hitches with no luck truck trailer are level . I was wondering if the problem is because of Independent rear suspension ? Need Help Jack.
Old Dec 27, 2015 | 04:52 PM
seventyseven250's Avatar
seventyseven250
Jack, have you taken this rig to a CAT scale to get the axle weights? That would be my first step.
1) take weight of expedition without trailer attached
2) attach trailer and get axle weights WITHOUT any WD bars or equalizer system engaged.
3) attach WD bars like normal and get weights a third time.
May need set 3b, 3c etc as you adjust the bars. But if youjust do seps 1,2,3 and post the weights, folks here can help a lot.
I had a very spooky steering feel once when towing without a WD hitch. It was from inadequate weight over the steering axle, and it went away one I had the WD equipment installed and adjusted using the procedure above.
There is also a procedure using a tape measure if you aren't able to get to a CAT scale. Apparently it works fine as well, but I like the scale method.
jvaski
2009 - 2014 F150
Feb 14, 2017 10:10 PM
ij72
Mar 6, 2014 11:36 AM
ilikefordtrucks
Large Truck
May 8, 2010 11:59 AM
Thomas A
Oct 30, 2005 02:35 AM
DannyGilx
Mar 15, 2002 08:24 PM
