3 Speed floor shift conversion
Old Dec 6, 2015 | 11:50 AM
Gater180's Avatar
Gater180
Hi, I have a 79 f150 2wd looking to convert my 3 on the tree to a floor, any tips or ideas or even pics that you could post would help. Thank you
Old Dec 6, 2015 | 12:01 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Go buy a common truck 3 spd floor shifter kit, install it and connect the shift rods.
Hurst, Jegs, Mr Gasket, Summit Racing.
Hurst 3-Speed Indy Pick-Up Truck Shifter | Hurst
Old Dec 6, 2015 | 01:13 PM
jim collins's Avatar
jim collins
You can go this way may not be any cheaper . This is a 4/sp top loader but you can do a 3 /sp top loader too. Ford provided the transmissions for the Jeep Cherokee from 76 to 79 with the ratios for Jeep. The 3 / sp would need top from the Jeep T-150 and the 4 /sp would need the T-176. I have a top for the 3/sp that i planed to put together but just have not taken the time to do it. I have read some place that a few Ford trucks in the 80s came with one like that, but have never seen one. The hard part is finding a good T-150 top and you have to take some of your transmission apart to convert it over. Works best in the old Ford cars where the guys want a shifter that looks original but with a more modern stronger transmission. Just another idea. JIM
Old Dec 6, 2015 | 06:58 PM
Gater180's Avatar
Gater180
thats a very interesting concept I must say I like the idea Im gonna look more into it for sure.
Old Dec 7, 2015 | 03:34 PM
Gater180's Avatar
Gater180
Does anyone know if the bench will be in the way of the shift throw?
Old Dec 7, 2015 | 06:59 PM
Willz74's Avatar
Willz74
I'd be more worried about the dash I haven't messed with one but I'm sure it's a short transmission
I have a t150 in my jeep if you need measurements off of that
Old Dec 7, 2015 | 07:57 PM
jim collins
Ford made the t 150 for jeep , all most the same as the ford 3 speed top loader. They filled it with the gear ratios that jeep needed and left off the ford tail shaft housing . Then they made the modifications in the main case to bolt up to the 4x4 transfer case. I had a friend that had one in a 51 ford truck behind a 302 engine. The shift lever might have to be reshaped a little if it hit the dash.
To put the jeep t-150 shifter on the ford top loader is to just remove the side shift forks , plug the holes and bolt it on using the same holes the removable top cover was to. If you have a ford 4 sp top loader you use the jeep t-176 shifter. Means taking the transmission apart to do it .
Old Dec 9, 2015 | 02:27 PM
Gater180's Avatar
Gater180
Does anyone have a pic of either their installation or have had any good/bad experiences with the conversion?
BradBryan58
Mar 9, 2018 09:07 AM
Sixoh
20
Jan 24, 2016 05:52 PM
echo
15
Apr 8, 2011 08:19 AM
One79one71
Dec 11, 2007 01:54 AM
Warhorse86
Jan 31, 2004 09:24 AM
