So like every other post I've made, I tried searching, but everything I found had links that didn't work.
I'm looking for 2 wiring diagrams. I need the diagrams for the headlight switch both with and without fog lights. I'm adding fog lights to my 2000, and I want everything to be factory in appearance. My plan is to use the circuit in the factory switch to control am aftermarket relay to control my fog lights, but I need to see a diagram to make sure its even possible.
You are awesome! It just so happens that the 2001 is the year I needed, since it appears to be the only year that had fog lights without auto head lights as an option. Thank you!
Do you happen to be able to post the diagram of the pinout for the headlight switch for that 2001? There should be a page in the manual that shows what color wire goes in which spot on the connector.
For anyone else interested in doing this, I will make a write up when I'm finished. It's kind of an expensive way to do it when you could just add a $5 toggle switch and be done with it, but for the sake of a factory appearance it is worth the time and money to me!
You are my hero! It looks like this will work! How do I send rep? I can't figure it out!
Also, what manual is that? I need to buy one.
To send well deserved reps to someone (like Nicmike for all of the great diagram help here!) click on the little scales icon in the upper right corner of his post, a new small window will open where you can tell him how awesome he is!
There is a thread here on the first page about that. I don't think he has finished yet. I assume it would either need a new GEM,or a reprogram, the sensor, switch, and maybe a few wiring changes
