Failed smog need help. Please
Old Dec 5, 2015 | 02:21 PM
380tommy's Avatar
380tommy
So I took the 6.0 down for smog here in CA and it failed. It showed EGR not "ready"
The EGR was just replaced recently since it was removed and had a delete on it. Is there anything I need to do so that it recognizes the EGR valve?
Old Dec 5, 2015 | 02:41 PM
87crewdually's Avatar
87crewdually
By chance are you running a tune that shuts off the EGR? If so, I'd return the PCM to stock using the tuner and then take it back.
Old Dec 5, 2015 | 03:32 PM
380tommy's Avatar
380tommy
No tune that I know of? Just picked it up from AZ last week. EGR was removed and blocked off so it was replaced with new EGR.
Old Dec 6, 2015 | 02:26 AM
HT32BSX115's Avatar
HT32BSX115
Howdy,
You did not indicate what year model this is....but if it's an 04(I think) or later and you remove or block off the EGR cooler, you must upload a "tune" to keep the MIL off.
After tuning, most tuners are not required to be left connected.
So you could still have the NON-EGR tune still in the ECM
You'll probably either need to take it to a dealer and have them flash the ECM with the latest OEM tune, or you'll need to use the original tuner to "flash" it back to the OEM tune (assuming it was "saved").
Regards,
Rick
Old Dec 6, 2015 | 07:33 AM
run6.0run's Avatar
run6.0run
When you mention egr,, are you talking about the valve that the harness plugs into?? There must be an egr cooler installed also. There are two (actually 3) parts to an egr delete. If you are going back stock,, all those parts need reinstalled.
Old Dec 6, 2015 | 09:27 AM
380tommy's Avatar
380tommy
It is an 04 built in 03.
Any idea what the dealer charges to flash it?
EGR cooler is still there, just the EGR valve was removed and a block off plate was installed. The plate was removed and a new EGR valva was installed. Everything else passed smog inspection but the EGR showed "not ready" when the smog tech checked it through the OBD2 port.
Old Dec 6, 2015 | 09:52 AM
run6.0run's Avatar
run6.0run
If it has a flat block off plate then the egr cooler is prob welded shut. The truck wouldn't run with no egr valve and a functioning egr cooler. I have seen egr valve block offs that look just like the egr valve,, meaning it goes into the bore,, rather than just capping it off. If you had one of those block offs that goes into the bore,, then what you are wanting to do should work. But if the block off was just a flat plate,, you are in for an intake removal.
Old Dec 6, 2015 | 10:59 AM
87crewdually
If the emission monitor was just "Not Ready" you may just need to drive it for awhile until the pcm does a self check and makes it "Ready". If you had disconnected the battery before inspection it will give you a not ready status. So drive it for a couple of drive cycles and then have it checked with a scanner to see if all monitors are "Ready" status.
Old Dec 6, 2015 | 12:13 PM
380tommy's Avatar
380tommy
Will the Torque app show me if it's "Ready"?
Old Dec 6, 2015 | 09:27 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I would question if you have a Stealth Delete or still have an SCT Tune loaded.
Josh
Old Dec 6, 2015 | 09:46 PM
87crewdually
Mine doesn't but it's NOT California emissions. Maybe someone who does can check.
Old Dec 7, 2015 | 03:13 PM
FiveOJester's Avatar
FiveOJester
Does the truck have the throttle plate still? I know they went back and forth with the 03-04 and finally got rid of it in 05.
Old Dec 7, 2015 | 04:53 PM
380tommy's Avatar
380tommy
Hmmmm I don't know? I will take a look when I get home.
Thanks for the detail, otherwise I would have no idea what the throttle plate is
Old Dec 7, 2015 | 04:56 PM
380tommy's Avatar
380tommy
I spoke to a local diesel shop and they said once the egr is replaced it needs to be driven so that the "system" sees the sensor. He couldn't elaborate on how long or how many miles it needs to be driven but he said the "system" will eventually see the egr and it will then show "ready"?
I'm getting more confused
Old Dec 7, 2015 | 05:40 PM
Bonanza35's Avatar
Bonanza35
Shouldn't take that long, 10 miles or so I would think. Who did the work on your truck? Did you buy it from a private party? Even an Az truck bought in California has to pass smog. If you bought it here there responsible.
