I'm trying to diagnose a 173 CM code.
Had a fellow tell me that the Cat was probably hollowed/burned out.
The thing has a Cat and a muffler and is still louder than my 351 running a Cat only.
I've replaced MAP, ACT, and o2.
ECT checked good.
Disconnected battery overnight to clear all adaptive strategies.
Same result.
There are no KOEO codes.
The 173CM will set every time when the engine comes up to operating temp.
ASSUMING the fuel pressure steps all passed ...
The next rungs of the ladder have all been done and passed.
The truck is indeed running rich.
Smell and/or black smoke verifies.
Seems logical to me that it indeed has to do with fuel pressure and/or injectors.
Thought maybe I'd run some injector cleaner thru it just to see what, if anything, happens. But to be honest I'm about sick of screwing with it. I have a mechanic that I trust. Was just hoping to save some $ and gain some knowledge in the process.
