On my 2003 F-350 Dually 4x4 drivers side rear shock mount is broken off where it is welded to axle. Ford says they don't have part have to get new axle...WTF
Any ideas out there on how to fix.
2 things come to mind. FIRST: Is there a GOOD welding shop in your area ??? They should be able to repair it.
SECOND: On single rear wheel trucks, the lower shock absorber mount clamps onto the axle tube. I don't know if the dually axle tube is bigger in diameter than the SRW tube, but you might be able to adapt the SRW bracket onto your axle.
