Fuse box
Old Aug 6, 2003 | 08:52 PM
opnekryan's Avatar
opnekryan
Question Fuse box
Ok... I own a 99' F-350 PSD and the cab lights and door lights do not come on when I open the door. Im sure its either a fuse or a relay, yet I do not have an owners manual or fuse box layout sticker anywhere! So heres the question, can anyone explain the layout or at the least the postition of the fuse/relay for the cab lights? Thanks Ryan
Old Aug 6, 2003 | 09:41 PM
wingit1x's Avatar
wingit1x
Fuse box
The courtesy lamps fuse is a 15 amp fuse located at the top of the fuse panel, second from the left. It also controls the egine compartment lamp, power mirrors, warning chime, and some others. If these are all working, you may have a problem elsewhere.
Hope this helps.
-David
Old Aug 6, 2003 | 09:43 PM
wingit1x's Avatar
wingit1x
Fuse box
Sorry, I just re-read your post and noticed the "99 Powerstroke" part. I was reading '97, so the layout I gave you may be incorrect.
Sorry for the misdirection.
-David
Old Aug 7, 2003 | 09:22 AM
fisher_of_man's Avatar
fisher_of_man
Fuse box
you can go to this site:
http://www.qualitycareservice.com
on the bottom left they will have a spot for glove box manuels. you can go into it and pull up your vehicle and if you want print it out so that you will have all the manuels for your vehicle. its free, except for the 50 to 75 sheets of paper you'll use printing it out. it will have a copy of the fuse box layout in there. It is in Adobe Acrobat because it is a pdf file....so you'll need that to open it. If you don't have it you can get it for free just about anywhere on the internet.
Old Aug 7, 2003 | 01:56 PM
Lucca's Avatar
Lucca
Fuse box
I also have a 99 PSD/manual. According to my manual, the fuse you're looking for is inside the passenger compartment fuse box. It's at location #14, which is the second column from the right, 3rd fuse down from the top. It covers the dome lamp, cargo lamp, and courtesy lamp and is a 10 amp fuse. The relay fuse is in the same box, far left column, top slot. I made a copy of all fuse positions for my 99 when I was installing a trailer brake box. If you want a copy, call my cell at 510-774-8269 and give me your fax number, and I can send it to you.
Old Aug 7, 2003 | 07:47 PM
opnekryan's Avatar
opnekryan
Fuse box
Wow... quick responses!! Thanks everyone! Fisher of Man, That is exactly what I needed, Thanks a million! I've been looking everywhere on the net, so I thought... Lucca thanks for the offer, I think Ill be fine though with this manual I downloaded. Anyway I'll try a new fuse and let you guys know what happens thanks again!
Old Aug 8, 2003 | 06:42 PM
opnekryan's Avatar
opnekryan
Fuse box
Well... I found the placement for the fuse... and still nothing! I'm curious now if it could be the relay?? Also the fuse was missing in the spot it should have been... Wonder why??? hopefully Ill find out soon!!
Any thoughts?? Thanks!
59CRL
Jan 1, 2014 07:05 PM
windsor94
1983 - 2012 Ranger & B-Series
Jul 21, 2009 02:25 PM
anttho
May 2, 2007 01:23 PM
Junkfood
Electrical Systems/Wiring
Oct 17, 2004 08:43 AM
Walking_Tall_0403
Aerostar
Nov 4, 2003 10:34 PM
