Looking for a diagram or link to find the layout on the fuse/relay panel inside the truck. I dont have an owners manual and the one in the tech folder is a dead link. Thanks.
Crap, they were working a few months ago.
Under the links for the owners manual years, you'll see a link titled: FMC Technical Resource Access
Click on that link and on the left side you'll see "Owners Manual"
If you click that link, it will give you a different way to get the owners manual than the link in ProjectSHO's sig.
The one in ProjectSHO's link doesn't always access the manual a person may want. A member in the 7.3L PSD forum tried to access his owners manual with that link and could only pull up the Spanish language version, while the FMC link in the Tech Folder gave the correct year manual, in English, with various printing versions available.
Yes it did say spanish version.... I did find the manual and download it. I was looking for the fuse/relay for the ESOF system. Turns out to be a 30 amp one. My 4WD didnt work as in the hub locking in auto. The 4WD light comes on and I checked all vacuum lines and they are good. If I lock the hubs and use the switch then she goes into 4WD. I guess I will take the hubs off next and check them out.
