Hi, new to this great informative site. Just purchased a 2013 F350 6.7l Platinum. Love the truck and wondering if anybody has ideas on adding a supplemental step to get into the truck. It has the running boards but I need a step that is a bit lower 4-6" that I could possibly mount to bottom of running boards. I did find a retractable bed step by AMP that looks like it would work as it swings down and then give it a nudge and it goes back up. I am not worried about crushing it on rocks etc, as I don't go off road. Anybody done something like this or additional ideas? Thanks
It's old information from my 2006, but I did the same thing on my 2011. I ended up building a mounting frame from angle iron purchased at Lowe's and using existing holes in the frame. The steps have been on the two trucks since 2007 and the only problem I've had was a burned out motor on one side.
I have a Kwikee Step Model 39 ordered from pplmotorhomes.com that will arrive on Monday. My truck is a King Ranch and we needed to put on a step for the wife, but she wouldn't give up the KR running boards. I think what I'll have to do is mount a 1/4 aluminum plate to the brackets that support the running board and then mount the step to the plate.
This step drops 6.88 inches. My running boards sit at 16 inches from ground to top of the boards. So the step will be about 8 inches below the top of the board which will be just about halfway.
just found this post. If possibe, can you send me info & photographs of the brackets you made for the retractable steps. My email is Dahlenchris@aol.com
thanks
