http://www.ebay.com/itm/CLOCK-Ford-Pickup-Truck-Bronco-1981-1982-1983-1984-11985-1986-F150-F250-F350/262179181747?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3Da38eca602f3549b594f8e91527780e80%26pid%3D100011%26rk%3D1%26rkt%3D8%26sd%3D141029332766
And a woodgrain bezel with the cutouts
I ~think the OP already has the clock in his truck. That is pretty standard with the woodgrain bezels. What he needs is a weave bezel with a DIN radio opening and clock windows. They exist but are not common.
Edit: my parts are in storage. I will probably be making a trip there late this week and I will check what I have. Do you need the instrument bezel also or only radio?
Did you get a chance and look and see if you had a bezel?
Sorry man, I didn't forget about you... We got a pretty good little snow storm here on Friday which put a wrench in my plans to haul furniture from storage in an open truck. I'm going to try for Monday or Tuesday if the weather cooperates. Alan if you are following this that is the reason I have not sent you pics of the horn pad either.
I did check the Flagstaff junkyard on Friday... there was a silver weave DIN bezel but no clock and a top screw tab was broken off. I will check the Prescott junkyard as well, possibly Monday or Tuesday when I'm in that area.
Sorry to keep you hanging... I spent about an hour digging around in my storage and did not find it. I did put a bunch of trim pieces inside my truck cab (parked outside my dad's shop) so I am thinking it is with that stuff. Grant me a little patience and I will find it. I just moved so there is still chaos from that. I checked the Prescott junkyard again, and all they had was a non-clock DIN silver weave bezel in marginal condition. I looked at the truck that I pulled mine from and it had no clock in it. This pretty well confirms that when I do find it, it is without clock holes.
Alan, I found the horn pad, I will PM you pictures.
I am in no hurry, thanks for all the looking I really do appreciate it!
Finally found it. Sadly I did not remember that one of the upper screw tabs is broken. Paint pen mark from the junkyard says I bought it in July. The silver weave finish is in nice shape. It is also the non-clock version. Sorry. If you still want it and want to try to do surgery on the clock windows let me know...
