Alternator bracket
Old Dec 1, 2015 | 05:16 PM
gameover1974's Avatar
gameover1974
Alternator bracket
93 ford f 150, is there a universal bracket that I can get in place of the original
Old Dec 1, 2015 | 06:54 PM
Diesel_Brad's Avatar
Diesel_Brad
No .............
Old Dec 1, 2015 | 06:58 PM
dixie460's Avatar
dixie460
Also consider that most brackets that are labeled "universal" are just junk that somebody threw together and it's up to you to make it fit your particular application anyway, so you might as well just make your own from scratch. That way you can design it the way YOU want.
What's wrong with your stock bracket?
Old Dec 1, 2015 | 07:23 PM
Briansshop's Avatar
Briansshop
Some of the Lightning guys are using this: March Performance Ultra Series Billet Aluminum Alternator Brackets 30055-09 - Free Shipping on Orders Over $99 at Summit Racing
Old Dec 1, 2015 | 08:21 PM
gameover1974
Can't get the alternator off
Old Dec 2, 2015 | 12:57 AM
fordbozo's Avatar
fordbozo
PB Blaster works wonders if you can get at the threads. On *another car* when I was replacing the suspension I started spraying all the bolts I knew I was going to have a hard time with every day for a couple weeks. When it came time to pull those nasty rusted nuts off of those nasty rusted bolts they popped right off.
Old Dec 2, 2015 | 06:34 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Phosphoric acid will eat up the corrosion seizing the bolt in the bracket.
It is found in boat and truck brighteners, some wheel cleaners and cola.
I wonder if sleeving the bolt with heat shrink tubing would keep this from happening?
Ford really should have put a brass bush in those brackets.
Old Dec 2, 2015 | 07:10 AM
rla2005's Avatar
rla2005
I agree..Ford should have used a better design. But my 1991 Bobcat 642B uses the exact same alternator bracket design as well. It's a conspiracy!
All kidding aside some heat and chemical action is in order here. PB Blaster and a little propane torch work busted each one loose in 30 minutes or less.
Old Dec 2, 2015 | 07:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's not the threads.
The bolt seizes *in the bracket*.
Then you have the whole bracket turning with the long pivot bolt.
Except... it can't turn because the water pump is in the way.
And the water pump bolts are *behind* the alternator bracket...
Old Dec 2, 2015 | 04:36 PM
gameover1974
Stuck
I will have to drill it out, what size bit should I use?
Old Dec 2, 2015 | 04:58 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
That's not going to work.
Cut it off with a sawzall or just a hacksaw blade *behind* the bracket.
Be sure to get the threads turning by moving the whole thing before you cut it.
Old Dec 2, 2015 | 05:25 PM
gameover1974
Too late I cut both sides
Tried everything but dynamite
Old Dec 2, 2015 | 06:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try some mild acid to dissolve the oxidation.
Drive it out with a drift or the replacement bolt.
Clean it out with a rattail file.
Grease the hell out of it
Consider putting a piece of heatshrink on the new bolt.
This will insulate the 'tunnel' and prevent future electrolysis.
Old Dec 2, 2015 | 08:12 PM
gameover1974
Thanks, I will definitely try that
Rhc86
Aug 25, 2016 10:22 AM
tinman52
Jun 14, 2014 09:27 PM
John & Old Ford
Dec 7, 2012 10:11 AM
95EBShortBed
Sep 8, 2012 09:41 PM
55forder
Feb 9, 2006 03:44 AM
