Timing issue?
Old Dec 1, 2015 | 12:11 PM
mountain dewd's Avatar
mountain dewd
Timing issue?
Hi everybody,
My frankentruck is having symptoms of possibly too far advanced timing, but I am not sure. Cruising down the highway at 60-65, all is well, if I mat it, it sounds normal until the revs rise a little more under a load, then it sounds like a ping, but not as rapid as you would think a ping usually is. Also, it makes a little bit of a knock or ping when initially cranking at a hot start. Oil pressure is good, motor is healthy and pulls strong. I will check the timing tonight. Any ideas? Thanks in advance!
Old Dec 1, 2015 | 12:48 PM
Filthy Beast's Avatar
Filthy Beast
Yup, it sounds like the timing is a bit advanced. Check your harmonic (balancer) dampener for wear when you check your timing. Sometimes the rubber insulation gets hard and falls apart, leading to a false timing reading.
On a hot re-start, does the engine labor while cranking before starting? (= too much advance).
Do you have a stock cam or a "bigger" one?
You could adjust the vacuum advance by turning an allen wrench in the vac advance nipple on the distributor....if the diaphragm is still good (check it) - and you have that feature. Older distributors have it....DS I and II have it. Something to check, 'cause the diaphragms do wear out/crack leaving the carb to suck air instead of advancing the timing under load.
Old Dec 1, 2015 | 02:33 PM
mountain dewd
Thanks for the reply! I will have to check the balancer.
Stiock cam, and it does labor upon hot start, most times. Occasionally it will not, but it usually does.
Old Dec 1, 2015 | 02:52 PM
HIO Silver's Avatar
HIO Silver
I concur with the Filthy Beast's input.
Yes, I mean that with no offense intended.
Old Dec 1, 2015 | 04:46 PM
mountain dewd
Checked for vac leaks and found none.
Looks as if the dizzy was out of adjustment. Set the timing back to 6° btdc and all is right in the world. Starts and runs much better!
72bronco1963
1966 - 1977 Early Broncos
Oct 14, 2009 10:43 PM
tygerrrr
Aug 29, 2009 02:01 AM
jdog34436
Dec 3, 2005 10:02 PM
Old5
Feb 26, 2003 01:55 PM
cdd5599
Oct 22, 2002 04:04 PM
