Sponsored by: Real Truck
reverse sensors intermit
Old Jul 25, 2011 | 05:33 PM
rattleNsmoke's Avatar
rattleNsmoke
On occasion I'll have the reverse sensors quit working. I'll drop the shifter in reverse and the 'OFF' light on the button will illuminate. I took the sensors out and blew them clean with compressed air, dielectric geased the connectors and reinstalled the plugs. Let's see if that does the trick.
As mentioned, it's occasional and nothing in particular will trigger the fault....it's very random. Something tells I have'nt seen the end of this problem, but tracking an intermittant fault is a bitch.
Old Jul 25, 2011 | 07:37 PM
Trophy_23's Avatar
Trophy_23
I had that for a while, then it went to 'off' all the time. Had the outside left sensor replaced under warranty and all is good again.
Old Jul 25, 2011 | 08:09 PM
popups4rent's Avatar
popups4rent
Next time it does it:
Shut off truck while still in reverse
Set parking brake
Turn ignition on to engage reverse lights, etc.
Go to back of truck
Stick your ear on each sensor.
The one that sounds different or does not sound at all is bad.
At least that worked for me.
Old Dec 30, 2011 | 12:07 PM
erniek70's Avatar
erniek70
all 4 sensors make a fast ticking soubd, yet my sensors still do not work. The off light remains illuminated.
Old Dec 30, 2011 | 01:56 PM
rattleNsmoke
The module on yours erniek. Mine was the d\s sensor.
Mike
Old Dec 30, 2011 | 08:44 PM
erniek70's Avatar
erniek70
you think it might be a bad module? Please confirm your previous response.
Old Dec 30, 2011 | 09:01 PM
Vinford's Avatar
Vinford
Where is the module located?
Old Dec 31, 2011 | 05:10 PM
Vinford's Avatar
Vinford
Same deal here .................
Old May 22, 2013 | 09:47 AM
erniek70's Avatar
erniek70
on the pickups, i foudn the module behind teh glove box, on the right side interior wall of the cab.
I repalced the speaker on the module, but still have issues. Will work momentarily (one quick beep), with a trailer hooked up to the trailer connector....but then does not work. Without a trailer, no sound at all.
Any ideas? I hate to replace a module that has nothing wrong with it. All 4 sensors click too.
Old May 22, 2013 | 09:30 PM
pbeering's Avatar
pbeering
Check the harness plug too. It is on the driver's side rear just outside the hitch and spare tire. Check for corrosion and gunk. Add dielectric grease or Fluid Film.
Larry NCKS
Apr 16, 2011 10:45 PM
dalman
2004 - 2008 F150
Oct 23, 2007 12:41 PM
rkmarine
Jun 17, 2006 10:14 AM
chopper269
May 3, 2006 09:46 PM
ajmommie
Apr 12, 2005 03:31 PM
