Hey guys so yes i'm a total newb haha. I'm starting to get interest in trucks since I got my 1981 Ford f150. So the question I have is how can I identify my 460 engine? I did manage to find some ID #'s. For my water Pump I found I found the #'s D2VE B-A and for my Head ID I found D3VE-A2A. I was wondering if you guys could possibly help me out in finding the year this engine was made ect. I do have a number that I found on the intake but i'm not quite sure if that'd help since it isn't a stock intake. Any help is appreciated!
You are aware that the 81's didn't come with a 460 - right? So, are you sure it is a 460?
As for your heads, they were engineered in 1973, and the water pump in '72. But, that's assuming you are getting the right numbers. A water pump carries the number 8501, and one for these trucks would be an E5TZ 8501-C. Similarly, the number for a head is 6049, and heads for these trucks would be E5TZ 6049-R.
Is there any way I can find out if it's a 460 Lincoln or any of that? I have an understanding that there are 351 m and 351 c so is there any different types of 460 as well? And if so how can I find out which one I have?
Well, for the 335 series at least, there were different block castings for the car vs truck engines - at least for the 400.... could very well be something similar was done for the 460 but I really don't know for certain... others can maybe help.... or you could maybe ask here:
if earlier D3VE it is internal balance and could be from a lincoln or truck.
C8VE would only be from a car because they weren't found in F-series trucks back in the 1960's
Just fyi, NVFord81, the "D" of D9TE is the decade, where "D" means 1970's and "E" means 1980's. And the "9" is the year within the decade, so D9 means the block was engineered in 1979. However, it was used for many years thereafter, but wasn't used prior to that.
