Don't floor it!!!???
Old Aug 6, 2003 | 05:32 PM
woodstockaz's Avatar
woodstockaz
Try to figure this out. '89 2.9L Ranger. Idles great, if you try to give it gas too fast, it boggs down. If you rev it up slowly, it works fine, but like I said, if you wanna accelerate, it just dosen't get enough gas and then backfires. Timing is 10* BTDC. I'm sure that all the plugs are firing, it's like the engine doesn't know you're trying to accelerate. Does anybody know if the sensors are the likely culprit and which ones are most likely???????
Old Aug 6, 2003 | 06:01 PM
FyreLyter's Avatar
FyreLyter
Is an 89 fuel injected or carbuerated?
Old Aug 6, 2003 | 06:03 PM
woodstockaz
It's Fuel injection.....distributor
Old Aug 6, 2003 | 06:42 PM
Scca28's Avatar
Scca28
Are you getting black smoke from the tail pipe?
Old Aug 6, 2003 | 06:44 PM
woodstockaz
No black smoke. Backfire is through the intake and I'm pretty sure that it is running too lean when I try to accelerate. What do you think?
Old Aug 6, 2003 | 07:10 PM
Ken00's Avatar
Ken00
I would start by checking fuel pressure, pulling codes and looking for vacuum leaks.
Old Aug 6, 2003 | 11:19 PM
woodstockaz
Hey Ken, you seem to be a lot of help to a lot of these guys, and I'm sure that you are much appreciated. I checked fuel pressure and got the following: No pressure Key On, Engine Off; between 20-28 psi with the engine running; no change with the regulator vacume removed; the pressure remains fairly constant once the engine is stopped for at least a few minutes. I put on a new fuel filter. The timing was TDC and I reset it to 10* BTDC where it belongs. The codes that I got are 11 or system pass whith the Key On Engine Off and 13,74, 77 with the engine running test. 13=cannot control RPM during low RPM test. 74=Brake switch is open 77=Operator error during dynamic response test or cylinder balance test. I don't know why it would not be able to control the RPMs during a self test or why there was an operator error. Do you think the fuel pump could cause this problem if it was low? Any suggestions as to my next course of action would be appreciated......Thanks
Old Aug 7, 2003 | 07:05 AM
FyreLyter's Avatar
FyreLyter
my Ranger pushes about 60 psi fuel pressure when running, but I don't know about 89's. Did you check it after the filter change? I changed mine recently and man was it plugged up! It caused a 'too much voltage to the fuel pump' or whatever code to come up. it went away with filter change and a little checking of the wiring system.
Have someone turn the key on and you listen to your pump with the gas cap off. If it doesn't purr nicely, then it's constricted or going out.
Those are some of my ideas, but I'm still learning...
Old Aug 7, 2003 | 10:59 AM
Ken00's Avatar
Ken00
That fuel pressure is low, I don't have my book but I beleive it should be arond 40psi. Have you changed the filter? If you don't have an idle problem I wouldn't worry to much about the 13. Is you idle speed set correct, is the throttle plate closing properly, do you have vacuum leaks, if you don't have any of these then clean/replace IAC.
Old Aug 8, 2003 | 03:15 AM
woodstockaz
Hey Ken, everybody, thanks for the help, I love this site and i wish there were more just like it. I replaced the fuel pump and problem solved....runs fast now too.
Old Aug 8, 2003 | 01:36 PM
Ken00's Avatar
Ken00
Glad to hear things are good now. Do you still get the 13 code?
Old Aug 8, 2003 | 03:07 PM
woodstockaz
Ya, I still get the 13, I couldn't find the IAC sensor though I know about where it should be. It dosen't have a pic in the Haynes.
Old Aug 11, 2003 | 08:55 AM
Ken00's Avatar
Ken00
The IAC is on the passengers side of the upper intake.
manuel transmission
38
Jan 13, 2020 12:24 AM
krmcg1
2004 - 2008 F150
Apr 30, 2012 07:24 PM
Chuck14
Jan 22, 2009 11:30 PM
aaronlockhart
Mar 30, 2007 07:00 AM
JBlock2337
Alternative Fuels, Hybrids & Mileage
Oct 22, 2005 01:50 PM
