Compatible Motor Swap?
Old Nov 30, 2015 | 05:40 PM
FarmerEd1983's Avatar
FarmerEd1983
Hello,
Quick question, I have a 84 F250 6.9 Turbo Diesel with a crappy body. Motor runs strong but the frame was cut to accommodate a hay hauler and doesn't have a bed or tail lights.
I wanted to see if i bought a 1986 F350 Dually Gas powered rig that has a blown motor would it be doable/worth swapping the motors?
Thanks,
Eddie
Old Dec 1, 2015 | 12:25 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You'll need to change over the engine perches, radiator *and* support, cab *and* engine harness, exhaust system, etc...
It can be done.
Whether it's worth it is up to you.
Old Dec 1, 2015 | 12:49 PM
82F100SWB's Avatar
82F100SWB
If the gas truck is a 460 rig, it does all bolt together, but it's still not a small project if you want it all to work as factory. You need to use the diesel trans or bellhousing if its a stick as well.
I have done my own gas cab on a diesel swap, as well as a 460 to diesel re-power on an 88, and both included complete harness swaps. None of it is really custom work, but it is no small project.
Old Dec 1, 2015 | 04:32 PM
FarmerEd1983
Thanks for the responses. I appreciate the time you took to reply.
uh60
Oct 28, 2013 08:28 AM
acummings3287
15
May 11, 2012 12:24 AM
2005f-150
32
Aug 4, 2010 09:57 PM
Bugzturbo
Apr 8, 2008 12:56 PM
fordtruckluver
Feb 12, 2002 09:54 AM
