My weekend project: engine install
Old Nov 30, 2015 | 09:14 AM
SRBF150's Avatar
SRBF150
Sounds like the lesson there is to leave the 38R compressor wheel it was born with alone. Or, are you saying that is the stock wheel?
That's an expensive story, holy mackerel.
Old Nov 30, 2015 | 12:30 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by bfife
...they are seeing the same thing. If you actually use your truck, the 38r/2nd gen wheel are not working. The manufacturer is denying it but I wouldn't recommend one to any one.
Someone made a comment about the aftermarket wheels for the 38R possibly causing 38R's to fail awhile back and I took note of his observation, that's why I asked.
Thanks, Barney.
Stewart
Old Nov 30, 2015 | 01:41 PM
scotttahoe's Avatar
scotttahoe
Looking nice there!
I am curious to see what kind of voltage (not from the gauge cluster) you are getting from the alternator.
Along with my rebuild I added a brand new alternator and was only reading 11.9 to 12.7. Not enough to give the batteries a good charge and will be dead the next morning. Bought 2 new batteries and had the alternator tested. The alternator was pushing 14.6 volts but my truck was not getting it. Found out the alternator was not getting ground through the powder coating. Once grinder down I'm now seeing 13.9 to 14.1 volts. Still need to clean off some more of the powder coating.
Old Nov 30, 2015 | 06:59 PM
bfife's Avatar
bfife
still plays with trucks
I get 13.9-14.3 at the battery. I learned this lesson a long time ago. i always run an 8 gauge wire from a negative post on the battery to the alternator case or a mounting bolt. that way you have a nice clean ground and your alt will last twice as long.
7.3 PStroke
46
Aug 9, 2016 07:48 AM
oldwood
Dec 29, 2010 07:04 PM
kdfishe43
Mar 31, 2010 01:22 PM
79F150EFI
Jun 16, 2007 08:34 PM
RubberDuck
Aug 11, 2006 02:26 PM
