Sponsored by: Real Truck
Transfer case problem
Old Nov 28, 2015 | 08:07 PM
fred2001's Avatar
fred2001
I have a 2002 f250 with a 4 speed auto. The problem is that the transfer case won't shift in to 4 low, but it shifts in to 4 hi with no problems. BTW it is electric shift. I have done the proper shift procedures, put it in neutral step on break ect. Any advice and tips would be appreciated. Thank you in advance
Old Nov 29, 2015 | 01:29 PM
dkf's Avatar
dkf
I have had the ESOF system be finicky going in and out of low range already. Seems to be worse when it is not used very often. What has worked for me in the past is letting the vehicle roll a little in neutral and then shift into 4 low. You have to screw around with it a little. Would not hurt to manually lock the hubs too and see if that makes a difference.(maybe one hub is not locking in) One of the reasons that when I got my new 04' I got the manual 4X4. Though the ESOF is darn handy when it works.
Old Nov 29, 2015 | 02:26 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Id take the motor off the tcase and see is dirt is packed in the motor. Id then clean and regrease the motor shaft and gear with some waterproof grease. Id also manually turn the shaft that moves the shift fork for high and low range and make sure it turns freely. If after that it still doesnt work and you have the truck in N and with brake applied and it still wont go into low, the motor might be weak and needs replacing
Old Nov 29, 2015 | 02:29 PM
SuperDutyScaler
When the esof works its beautiful, only readon i removed my esof hubs was because everyone i knew with a SD with the esof was having problems and i was so sick of fixing their trucks i just removed mine, installed a plug into the knuckle and removed all the vacuum lines back to the pump and capped it just so i would never have an issue. It does suck that i have to het out and lock in my WARN hubs but it was worth it i suppose. If i ever can afford a brand new truck it will have the manual tcase though...
Old Nov 29, 2015 | 03:16 PM
fred2001's Avatar
fred2001
Thank you all for your advice. Dkf I did what you suggested and it worked, thank you, you're a rock star. So what do I do to fix the problem?
Old Nov 29, 2015 | 03:48 PM
dkf's Avatar
dkf
Which did you do? Manually lock the hubs then try to switch to 4x4 LOW? Or let the truck drift a little while shifting into 4x4 LOW?
Old Nov 29, 2015 | 03:50 PM
fred2001's Avatar
fred2001
I manually locked the hubs in.
Old Nov 29, 2015 | 03:59 PM
dkf's Avatar
dkf
There is probably a vacuum leak somewhere in the system or a component failure then.
A vacuum pulse is what locks the hubs when the switch is turned to 4X4. If the hubs are not locked the tcase will not want to shift into 4X4, especially 4X4 LOW. Having the hubs locked allows everything to mesh properly. You can feel it on a truck with a manual transfer case easier than with the ESOF, that the gears don't want to mesh when the hubs are unlocked.
Old Nov 29, 2015 | 06:04 PM
fred2001's Avatar
fred2001
It seems to me that the Esof system is too prone to failure. I think I will do what super duty scaler said he did and be done with it. Is there any adverse problems with using manual hubs?other than the convenience of not having to turn the hubs in.
Skagganetti
Dec 18, 2015 04:49 PM
mscott
Apr 22, 2015 04:24 PM
FourWheel
Mar 7, 2008 09:31 PM
kameronth
1978 - 1996 Big Bronco
Jan 23, 2004 05:56 PM
CO4x4SD
Oct 20, 2002 02:05 PM
