transfer case issues
Old Mar 7, 2008 | 07:16 PM
FourWheel's Avatar
FourWheel
I have a 92 150 4x4 and when i lock the hubs in 2 hi i have 4 wheel when i shift to 4 hi is like four low whats going on here?
Old Mar 7, 2008 | 07:17 PM
FourWheel's Avatar
FourWheel
sorry truck has a 351
Old Mar 7, 2008 | 07:58 PM
quisp-n-quake's Avatar
quisp-n-quake
what does it do in 4x4 low?
Old Mar 7, 2008 | 08:19 PM
FourWheel's Avatar
FourWheel
Well actually this is where it gets weird if the hubs aren't locked i shift into 4 hi and it is normal and shift into 4 low and its normal but if i lock the hubs i can't get it into 4 low
Old Mar 7, 2008 | 08:21 PM
FourWheel's Avatar
FourWheel
i also haven't really tried that hard to get it into 4 low with hubs locked either
Old Mar 7, 2008 | 08:39 PM
quisp-n-quake
yea, thats sounds kinda goofy...so its sluggish when its in 4H ? what if you put it in 4Low, and then locked the hubs??
is it a borg warner transfer case?
if there is a torque build up, sometimes you have to put it in reverse for about 20 feet to unwind the torque, then try to drop it into 4L you could have some worn forks too, I bent my 4L shifting fork and I can only run 4H -1356 borg w-there pretty simple to figure out, there really isnt much to them inside.
Old Mar 7, 2008 | 08:49 PM
FourWheel's Avatar
FourWheel
sounds like i need to take a better look at it tommorow will try locking the hubs when in 4 low just got truck a few wekks ago so i'm not sure on what kind of transfer case
Old Mar 7, 2008 | 09:02 PM
quisp-n-quake
Near the rear driveshaft it should be cast in the aluminum above the drain plug, or filler plug as a 1356,1345 etc look for the "borg warner" name.
its probably a 1356, also, did this truck have a plow on it? -that'll beat up the drive train,espeacially the transfer case forks, it could just be sloppy where its 16 years old. good luck.
Old Mar 7, 2008 | 09:31 PM
FourWheel's Avatar
FourWheel
thanks for the replys very much appreciated will check it out tommorow and post again
