OEM or Redhead
Old Nov 28, 2015 | 07:21 PM
g00d4me's Avatar
g00d4me
OEM or Redhead
I am about to start my excursion christmas shopping and I was wondering what steering gear i should go with, redhead or oem?
I read the group buy page and there were people with a few issues with them and i was thinking just to go with oem, but I'd like to hear the advantages/disadvantages going either way.
Also, since im replacing that, what else should i be replacing while im doing that?
should i go oem with those parts or is there an aftermarket brand that people recommend?
Old Nov 28, 2015 | 07:38 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Go with who you are comfortable with but here is the difference.
Oem,
Ford dealer sells remanufactured boxes under the motorcraft brand name. They are rebuilt to motorcraft specs by subcontractors and are backed by a 12 month warranty. They are the best of the big name job shop remams in my opinion.
Redhead
Is a small boutique shop that remnufactures original ford boxes to tighter tolerances then the big jobs shops. Also with a 12 month warranty.
Brand new steèring boxes are not available for your excursion. They are all remanufactured.
Old Nov 28, 2015 | 07:41 PM
LivingLarge's Avatar
LivingLarge
OEM is now 2 year warranty......
You couldn't pay me enough to run a redhead box period
Old Nov 28, 2015 | 07:48 PM
pirate4x4_camo
What else should you replace while you are at it ?
What ever is worn out ?
Steering shaft
Ball joints
Tie rod
Drag link
Radius arm bushings
Leaf spring bushings
Shackle bushings
Unit bearings
If it moves, it wears out. If it's worn out, replace it.
Old Nov 28, 2015 | 10:41 PM
wpnaes's Avatar
wpnaes
Tighten the box you have and see how that works. Will give you more time to make your decision.
Old Nov 29, 2015 | 12:10 AM
A Rodder's Avatar
A Rodder
I am a happy Redhead customer.
Wouldn't hesitate to do business with them again. I ordered one for mine, then a friends EX a month later. We're both happy with them.
Old Nov 29, 2015 | 01:08 AM
DidieX's Avatar
DidieX
I have to agree with Michael on this one. Go oem. If there's an issue it'll be easier to sort out. I'm not saying redhead is junk, but they don't seem to have very good quality control and as such it's a bit hit and miss.
Old Nov 29, 2015 | 01:51 AM
Stewart_H's Avatar
Stewart_H
It seems to me, the problems I've see with the Red Head units are ones produced during a run for large group buys, of which FTE has had two of their largest.
That being said, I have a perfectly functioning Red Head unit on my Ex, and a newer OEM unit on my F250 and I cannot tell a difference between them both.
Stewart
Old Nov 29, 2015 | 09:07 AM
g00d4me's Avatar
g00d4me
How would I go about doing that?
Old Nov 29, 2015 | 09:28 AM
wpnaes's Avatar
wpnaes
Give me a minute, Looking for that link...(or set of threads covering the topic).
http://www.thedieselstop.com/faq/949...les/042601.pdf See section on Steering gear mesh load adjustment. 1/4 turn, then tighten and drive re-test as Michael recommends. Not implying you have oscillations, but the step by step instruction is described there.
Stewart
That's a great observation Stewart.
Old Nov 29, 2015 | 02:15 PM
Jesser02EX's Avatar
Jesser02EX
I installed an OEM unit on my EX and very happy with it.
Old Nov 29, 2015 | 02:18 PM
LivingLarge
1/4 turn at a time, I can't stress this enough....
When I had my previous Ex done, I't took a total of about 3/4 turns to make it tighter. You don't want to over do this, I recommend you drive her a little between 1/4 turns.
Old Nov 29, 2015 | 04:57 PM
Stewart_H's Avatar
Stewart_H
Wow, I saw your post Sean and wondered why you were linking to another site for steering box adjustment when I've posted it over a hundred thousand times here on the forum (I just counted each post and it was actually 100,001 times to be exact... ) and have also posted a link to the instructions in the tech folder, when upon further investigation I realized there isn't a link in the tech folder!
What the heck...how could THAT have fallen in the cracks?
Oh well....rectified!
Stewart
Old Nov 29, 2015 | 05:57 PM
Bently_Coop's Avatar
Bently_Coop
^ must have been more concerned with the outcome of your skin and Bacon.
Old Nov 29, 2015 | 06:04 PM
IMASAP's Avatar
IMASAP
Didn't you put a Redhead in your Ex ? Or no ?
