1975 disc brake conversion.
Old Nov 28, 2015 | 04:57 PM
gthiboy's Avatar
gthiboy
I have used the search function but to no avail.
I'm wanting to go with disc brakes on the front maybe the backs too but was wondering if I can't get a hold of a 78-79 front axle is there a way to go about the conversion without the swap?
A guy on a facebook post the other day mentioned the axle and spindles are all the same on 75s and 76s and I can just tear down the 75 stuff to the spindle and install 76 brake/hub parts. Any truth to that?
Old Nov 28, 2015 | 05:36 PM
HIO Silver's Avatar
HIO Silver
You're referring to a 4WD, right?
The "guy" is incorrect.... The axles are the same but the spindles are different.... In order to swap to discs, you'll need everything from the knuckles outwards... and swap to later steering links because the tie rod shanks are thicker than your 75. The later steering arms on the knuckles have more "meat".
Here's a how-to..... It's for a early, drummed Bronco but it's the same overall...- Classic Broncos .com - Tech: F-150 Disc brakes * 66-77 Early Ford Broncos
Old Nov 28, 2015 | 05:42 PM
HIO Silver's Avatar
HIO Silver
Here's what you'll need:
Old Nov 28, 2015 | 05:59 PM
gthiboy's Avatar
gthiboy
Thank you. Yes truck is a 4x4 but a F-250. Does that make a difference?
Old Nov 29, 2015 | 12:20 PM
crazy96863's Avatar
crazy96863
This would also the require steering linkage from the 78-79 up to and includig the pitman arm.
Old Nov 29, 2015 | 12:22 PM
crazy96863's Avatar
crazy96863
I would imagine its the same principal as with the half-tons. But the components are going to have different specs when compared.
Old Nov 29, 2015 | 08:31 PM
CurtLarson's Avatar
CurtLarson
If your talking an F250, you'll need a whole front axle. Drum brake fronts are closed knuckle on the f250s
Old Nov 29, 2015 | 11:15 PM
wyrm73's Avatar
wyrm73
I have been studying this same idea as a future upgrade and initially struggled myself as to why the knuckles had to be replaced. I finally found the answer and there is a fairly large indented section on the disc brake knuckles to clear the caliper. As already mentioned, the spindle is different as well, but I have yet to find the actual difference.
I have however deduced from various parts sources that 1976-86 and 89-93 hubs are interchangeable and rotors are good from 76-93 if that helps in assembling all of the parts. Can anyone confirm this? If so, are the spindles interchangeable from any of the same years as the hubs? Dents are hard to come by in wrecking yards in my area- too old for the yards to carry and too many of them still on the road since we don't salt our roads out west. 80's on the other hand are a pretty common find.
Old Nov 30, 2015 | 10:53 AM
ZarK-eh's Avatar
ZarK-eh
how about a pic of what you have now?
Someone mentioned the f250's are closed knuckle design and you needs another axle.
As for using newer parts, I've taken newer 90's hubs and they work on my '78, while the spindles didn't. I would venture a guess and say that using the knuckles out from that same 90's truck would have worked, but then it would be a nightmare getting parts if anything went wrong. So I only used the hubs and tossed the spindles.
I can't imagine why a newer f250 dana44 front end couldn't be used to upgrade yours. except it's all twin I beameup so no idea is it'll work knuckles out or not.
edit: too bad you guys are so far down south, I have a set of dana44 f250 knuckles to hub from a '77 sitting on my porch floor waiting to head back into storage. Probably cost at least $100 bucks to ship because of it's weight.
tinman52
Jan 22, 2014 04:35 PM
74ford4x4
Jan 19, 2011 12:52 PM
Wolfinstine
Mar 6, 2010 07:54 AM
rhetor
Mar 28, 2009 10:03 PM
gwinters3
Nov 19, 2008 11:42 AM
