AIR shocks
Old Nov 28, 2015 | 04:31 PM
blue924.9's Avatar
blue924.9
AIR shocks
Anyone one ever run air shocks? I'm thinking of putting them on my f150 as the shocks on now are rusted out and basically non existent and it rolls like a dog on corners even at 10 mph. Dad has them in his 81 trans am and handles real nice but it doesn't tow or haul a thing so I'm wondering if they work on trucks or not.
Old Nov 28, 2015 | 07:16 PM
JRS2's Avatar
JRS2
Yep I have 'em. I think many folks here don't recommend them for weak springs for the additional force placed on the mounting points. I went with one more leaf spring in the rears, that raised the rear end another inch or two and my shocks needed replacing like yours and went with Gabriels I believe, sold thru autozone they recommend min of 25 psi so that is what I run them. Work good for me, no problems. When running the airlines where going thru the frame I used electrical flexible tubing so the chafing wouldn't wear them thru too soon ....
Old Nov 28, 2015 | 08:25 PM
blue924.9's Avatar
blue924.9
Not going to use these for making up for weak springs, my springs are fine my shocks are just bad. I know the rear shocks mounting points are broken easier than most so I'm not going to use shocks to try and haul more
Old Nov 28, 2015 | 08:36 PM
85e150's Avatar
85e150
Buy good standard shocks.
If you don't like body roll or leaning in corners, upgrade your front and add a rear anti-roll bar>
Hellwig - Load and Sway Control Products
Old Nov 29, 2015 | 07:53 AM
Nothing Special's Avatar
Nothing Special
I agree. Shocks are for damping out oscillation. Springs (including torsion springs, such as a sway bar) are for supporting loads, including the transferred loads due to cornering.
Air bags are another option for a "spring" to reduce sway, but putting then inside the shock isn't the way to do it.
Old Nov 29, 2015 | 08:03 AM
bashby's Avatar
bashby
I agree. Try new shocks first then if you still want less body roll lok into sway bars. Stiffer springs ( such as air shocks) will make your truck handle like an unloaded f350.
Old Nov 29, 2015 | 12:19 PM
blue924.9's Avatar
blue924.9
Okay so I'm going to try these on the front
More Information for MONROE 58275
And these on the back
More Information for MONROE MA771
Unless anyone thinks for some reason it will be a bad idea, they are only 50 bucks per pair so I think it will be interesting to try them
Old Nov 29, 2015 | 07:47 PM
GypsyR's Avatar
GypsyR
I got fed up with the body roll on my older F150 and robbed the front anti-roll bar from a junkyard 4 wheel drive truck (actually a Bronco). I like the improvement enough that I hunted down a rear bar from a truck with the factory tow package and then I was really happy. (There's this one llllooooonnnnggg sweeping freeway onramp you see)
My newer F150 came with the tow package and dual stabilizer bars already. If I were missing one or both you can bet I'd be straight off to get some. They made a world of handling difference to me.
And new shocks are almost always a good thing, for a variety of reasons.
Old Nov 30, 2015 | 07:57 AM
Air Lift Company's Avatar
Air Lift Company
Former Vendor
Let me know if you have any questions about out adding air bags to your suspension. They will help with stability and will offer load support while towing or hauling.
rodneywar
Aug 26, 2012 10:10 PM
turboboost
Aug 31, 2009 11:20 PM
broncobillyII86
Bronco II
Feb 23, 2006 02:46 PM
yozsi
Oct 1, 2004 12:16 PM
ASH
Jul 19, 2003 02:39 PM
