Ford Cetane booster
Old Nov 26, 2015 | 06:35 AM
Magnolia Tom's Avatar
Magnolia Tom
Ford Cetane booster
Picked up a bottle at the dealer a couple days ago. I put about 6 oz in the tank and filled up. After about 1/2 a tank the lie o meter is saying 18.3! Usually it's around 16.8-17.0-- which gives me about 15.5-15.8 mpg hand calculated. I'm anxious to see what the numbers are when I refuel but if it stays on track, that's a pretty good increase in economy.
Anyone else have this kind of improvement? Btw, I got fuel at my usual place.
Old Nov 26, 2015 | 07:36 AM
Rusty Axlerod's Avatar
Rusty Axlerod
My truck liked it also . MPG gains were a little more modest (.5-.7) but it runs better, sooner on a cold start using the addative, I think that's where the improvement came in. Fuel consumption is crazy high for me on a cold start.
Old Nov 26, 2015 | 03:29 PM
WatsonR's Avatar
WatsonR
I just picked up 4 quarts of this to try as well. Was using Opti-Lube, we'll see what happens. Already at 15.5-17mpg in the city.
Old Nov 26, 2015 | 03:47 PM
lupuseven's Avatar
lupuseven
Always see a 2-3mpg gain when I use it. Sometimes I just cant get to dealership before they close and I have to go a few tanks with out it,I always buy 5-10 bottles because of that. Definitely notice the difference every time.
Old Nov 26, 2015 | 06:44 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
pm-22 works great!
Old Nov 26, 2015 | 08:28 PM
Forddiesel06's Avatar
Forddiesel06
I have used this product since I have own this truck,and it runs a lot better even in cold starts and a little improvement on mpg.
Old Nov 28, 2015 | 04:57 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The engine in both my trucks ran noticably smoother. My Dad took Rudolph to Louisiana and pulled 19.4 mpg coming home. 6 hours to Houston.
The Monster ran noticably better even with questionable injectors. Since replacing the injectors with used ones and resealing them, the truck runs night and day better and much smoother with the PM-22 additive.
It's really the only one I'd recommend for people who's trucks I work on. It does a great job of lubricating things and bringing thr cetane up to acceptable levels and it's recommended by Ford.
Oddly enough, it also cleaned things up on some of the questionable injectors I had. I can't think of any additives that successfully did that or atleast bought me time.
Old Nov 28, 2015 | 07:52 PM
Yahiko's Avatar
Yahiko
You got me to thinking about this. In the past when I pulled the EGR valve
the soot was less and just a bit softer. Now that I have the EGR tuned to an off state
it does not show at all but I agree that the engine does seem to run better.
Sean
Old Nov 29, 2015 | 01:06 AM
CycleVIN's Avatar
CycleVIN
I use Amsoil Diesel Injector Cleaner and their Cetane Boost as well in every tank and you can notice a much smoother idle and acceleration than without it. Also, my MPG increased as well 1-2 miles per gallon compared to running straight diesel # 2.
Old Nov 29, 2015 | 07:55 AM
Macrosill's Avatar
Macrosill
Originally Posted by Curt's05
pm-22 works great!
Are you using the PM-22 and the Diesel Kleen or Fuel together?
Is anyone usign the Ford PM-23 in the winter compared to Diesel Fuel?
Old Nov 29, 2015 | 08:28 AM
69cj's Avatar
69cj
When I had my 05, I used both the pm-22 and DK. Never really noticed any diff. with either to include mileage. When I got my 6.7 I used up my existing stock and quit using the stuff. I never noticed a diff. on the 6.0 or 6.7. If I lived where it freezes I would def. use the white bottle.
Old Nov 29, 2015 | 09:55 AM
jswartz84's Avatar
jswartz84
Without using PM 22, my EGR valve was completely plugged after 17k miles. I started using it back in '07 and this was the first time I cleaned the valve 40k miles later.
ponch37300
6.7L Power Stroke Diesel
21
Nov 26, 2016 01:20 AM
my_crib_too
Jan 10, 2015 02:20 AM
Buck Dharma Fan
Nov 19, 2011 07:38 PM
Rusty Axlerod
Mar 29, 2011 06:20 PM
captian diesel
Feb 26, 2005 09:45 AM
