Anyone care to comment?
Old Nov 25, 2015 | 11:07 PM
ramsay's Avatar
ramsay
I have cyl 4 code and these two pics. The spikes down are sometimes regular and sometimes not. Should I be concerned about FICM?
Old Nov 25, 2015 | 11:17 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Sadly, yes. Any dips below 45 aren't good. We actually don't like seeing lower than 46.
Did you have an alternator or battery go out on you recently?
Regardless, we can set you up with a repair of your unit or could get you going faster on an exchange.
Hope this helps!
Old Nov 25, 2015 | 11:21 PM
04badford's Avatar
04badford
Ouch Eds got ya covered
Old Nov 25, 2015 | 11:50 PM
ramsay's Avatar
ramsay
What's up with the ICP readings? As a side note, I have been watching the FICM readings for a while but not on the graph. On the digital display it never drops below 47.5 volts.
Old Nov 26, 2015 | 02:58 AM
Yahiko's Avatar
Yahiko
Digital gauge is showing a sample that may be an average between
the sample times. The trace should be "live"' and you will see every bump.
That is the problem with digital. You have to know the sample rate
and it it's averaging or not. But sometime the scope type trace is too
much info to work with.
Ramsay, What are you using to show the trace for the FICM?
BTW You should see the IDS trace for the alt output. No big dips
like yours but it does have some saw tooth to it.
Sean
6.0L Tech Folder
Old Nov 26, 2015 | 09:10 PM
ramsay's Avatar
ramsay
I have AE which is what the pics are of.
Old Dec 5, 2015 | 08:33 AM
ramsay's Avatar
ramsay
I did a battery load test and one of the batteries is toast. So I guess to answer your question...Yes. On a side note. can anyone tell me what the voltage should read while cranking?
Old Dec 5, 2015 | 09:06 AM
69cj's Avatar
69cj
Sean
6.0L Tech Folder
If a digital didn't average you wouldn't be able to read them 1/2 the time.
Old Dec 5, 2015 | 10:10 AM
Misky6.0's Avatar
Misky6.0
You might want to watch the two 12v INPUTS to the FICM, your ficm power relay could also be intermittently dropping.
Old Dec 6, 2015 | 03:06 PM
FICMrepair.com
Former Vendor
Dips down to 11 are common, but down to 10 is also considered okay for a short period. If you see 9's, that's certainly less than incredible and a reason to consider more capable batteries, a time to clean up grounds, or a time to ensure that your starter isn't starting to go south.
Hope this helps!
Old Dec 6, 2015 | 05:49 PM
Yahiko's Avatar
Yahiko
With the new 850 CCA batteries when I do the first start of the day.
10.x does flash on for just a blink then back up as it starts right up.
But the real voltage is +0.5 higher do to the SGII way of reading it.
So I really think it more likely in the 11.5 or more range.
Marry Christmas
Sean
6.0L Tech Folder
V10RP
Modular V10 (6.8l)
Nov 22, 2014 09:33 PM
ninerM1000
6.7L Power Stroke Diesel
Sep 6, 2013 04:23 PM
1andonlywhitie
May 11, 2012 07:57 AM
VerbalKint
1947 and Older Ford Trucks
Oct 3, 2011 10:44 PM
V10RP
Modular V10 (6.8l)
Oct 30, 2008 08:38 PM
