Knocking from transmission
Old Nov 25, 2015 | 04:10 PM
steventerzich's Avatar
steventerzich
I just started hearing a knocking noise from what sounds like between the tranny and engine, it speeds up with increased throttle and back down, checked my oil its was fine level wise but there was a white residue looking stuff on the tip, wiped it off tried it again still there checked my antifreeze and it was low and haven't had the chance to add more checked all my other fluids and they were fine, I drove it back home and the white residue was gone but the knocking remained, I almost the flexplate was bad but wanted to see what everyone had to say, all advice is welcome and very much appreciated. 95 F150 302 5 speed 4x4
Old Nov 25, 2015 | 06:36 PM
dixie460's Avatar
dixie460
If the residue burned off after your drive home then the engine is probably okay.
Check the nuts that hold the torque converter onto the flexplate, these can loosen up and make a racket.
Old Nov 25, 2015 | 06:55 PM
steventerzich
I have a 5 speed manual so I couldn't have a torque converter problem, any other ideas?
Old Nov 25, 2015 | 06:58 PM
dixie460's Avatar
dixie460
Okay... then you don't have a flexplate, you have a flywheel.
If your clutch is knocking then it may have a broken spring.
Old Nov 25, 2015 | 07:01 PM
steventerzich
Not sure if it is the clutch or not but that's approximately where the sound is coming from
Old Nov 25, 2015 | 07:08 PM
dixie460's Avatar
dixie460
If I could listen for you I would but that ain't happening since you're in Nebraska and I ain't, so you'll need to narrow it down on your own.
You can buy a mechanic's stethoscope for just a few bucks, or use a short section of wooden handle like from an old broom to listen as well.
Does it do it regardless of whether the clutch is in or out?
Old Nov 25, 2015 | 07:37 PM
88XLTLariat's Avatar
88XLTLariat
Also, check for loose u-joints in that area. Put your truck in neutral, apply E-brake or chock wheels, and grab your drive shaft to see if there's any excessive movement.
Old Nov 25, 2015 | 08:44 PM
Bird-Dog 250's Avatar
Bird-Dog 250
I had something similar on a GM 4 speed. It was a broken tooth on one of the gears. Different car I know and a long time ago but could happen to a Ford. I'd be guessing but a shaft that's cracked would also give the sound and not necessarily self destruck.
Old Nov 25, 2015 | 10:33 PM
steventerzich
Drive shafts are fine along with ujoints just replaced them, the sychro was going out in 2nd but knocks in any gear, thinking maybe rods?
Old Nov 27, 2015 | 06:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
can you do a video with sound so we can hear it? that will probably help us narrow it down.
Old Nov 28, 2015 | 04:47 AM
steventerzich
Ya I could probably do that, can I post it to this thread? Sorry I'm new to this site
Old Nov 28, 2015 | 08:28 AM
tjc transport
i ain't rite
sure can!!!
seeing as you are a new user, i would post the video to a photo sharing site like photobucket first, then copy and paste the link here. it will be easier than trying to figure out our downloader.
RetroActv
2004 - 2008 F150
Jun 29, 2010 07:17 AM
roddy79
Jul 8, 2008 06:05 PM
bikesandcars
May 11, 2007 11:12 AM
AgentOrange
1997 - 2003 F150
Sep 2, 2003 10:43 PM
explorerxlt94
Jan 26, 2002 10:31 PM
