What's wrong?
Old Aug 6, 2003 | 01:37 PM
Ol' 86's Avatar
Ol' 86
What's wrong?
I have a 86 f150 with the 300.
If I jab the gas it stumbles and almost dies. If I ease into the gas
it revs fine. 1st and 2nd gear runs decent but 3rd and 4th it will
barely pull it's self. Also, 50 mph is about top speed. More gas I give it, the slower it goes, and starts to stumble.
Old Aug 6, 2003 | 02:05 PM
fordeverpower's Avatar
fordeverpower
What's wrong?
Almost sounds like a choke problem on the old carb but after 5 minutes it should drive fine.
Old Aug 6, 2003 | 02:43 PM
Chuky66's Avatar
Chuky66
What's wrong?
sounds like you might have a timing advance problem??
Old Aug 6, 2003 | 03:26 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
What's wrong?
Could be timing advance - or it could be a vacuum leak... which would cause timing issues too. Check all of your vacuum lines and I suspect you will find the problem.
Old Aug 6, 2003 | 03:49 PM
bremen242's Avatar
bremen242
What's wrong?
sounds like the choke is broken.. warm it up and take a piece of wire and wire it open, then try to drive it.
blake8105
Feb 19, 2015 10:59 PM
vmornbcr
Jul 6, 2013 05:37 PM
mucmuc
Jun 15, 2012 02:58 PM
stangman_86
1983 - 2012 Ranger & B-Series
Feb 25, 2006 08:29 PM
blue_mule
Dec 3, 2002 04:31 PM
