Straight Six Stumble under load
Hi guys - new here.
I have an 86 F250 with a 91 fuel injected straight six and 4 speed in it. Engine is strong as an ox, but it has developed a massive stumble under load. So bad that I have to shift down to 3rd to gain speed again.
Any ideas? Any help is much appreciated!
Fuel would be my first to investigate. When was the fuel filter last changed. If you have a fuel pressure gauge, check your pressure at the rail. I'm not sure what it should be, but someone else will chime in. Maybe 40-45 psi. Search for Conaski's posts. I believe he posted the number recently.
Many thanks,
I put in a new fuel pump and filter - did not change anything. I did not measure at the rail though...
Also, and this may be normal, there is a pump in the tank and one under the floor rail driver side door. I think the pump under the driver door is supposed to boost the pressure to around 50PSI. Does that sound right?
Shawn Paris
08-02-2016 10:56 PM
Trapping
04-26-2011 08:04 PM
DJdemon6696
27
12-02-2007 04:43 PM
