IPR dropping Help
Old Nov 24, 2015 | 10:21 AM
cheezit's Avatar
cheezit
When the issue is present
Old Nov 24, 2015 | 10:36 AM
Will Bite's Avatar
Will Bite
When it started this morning Temp was ECT 170. IPR was only thing that was any different than any other morning. I've had truck since new and never seen it go that low or stumble. EBP replaced last winter. It wasn't really cold out last night maybe 30. Most cold days it's at 26-28% at idle cold start. After warm it will idle at 22-23%.I high idle my truck every morning before I pull out from work maybe 15 min. And never had a problem.
Old Nov 24, 2015 | 11:06 AM
Will Bite's Avatar
Will Bite
The injector stiction issue. I was under the impression that the stumble or miss I was experiencing was from the drop in the IPR. Does one have nothing to do with the other? Meaning the drop in IPR wouldn't cause the miss or stumble and the injector stiction wouldn't cause the IPR to drop.
Old Nov 24, 2015 | 02:07 PM
cheezit's Avatar
cheezit
Ipr controls high pressure oil to the rails. That oil is used to fire an injector if you have a stuck coil it can act as either a blockage or a leak.
White smoke and misfires normally come down to the things I have listed. Suggestions for easy non intrusive testing have been given. Thats not to say you dont have a random odd ball but you now have a place to start.
Your seeing a symptom from you problem.
Old Nov 24, 2015 | 08:59 PM
Will Bite's Avatar
Will Bite
Thanks for your help. Will try it in morning.
dirthawg
6.7L Power Stroke Diesel
13
Oct 7, 2020 09:47 PM
Gabriel Shirk
1997 - 2003 F150
Jan 21, 2019 02:54 PM
N2S3
Apr 5, 2018 09:35 PM
acf6
Dec 23, 2015 12:35 AM
skotyg
Oct 24, 2012 02:08 PM
