Blower Motor Going Out?
Blower motor going out?
Not fun getting to one of those if its buried inside a lot of the Club Wagon interior trim. Worse yet is an aftermarket unit that was installed by a converter all those years ago.
Yes I thought about that today, checking the power when it is stopped..
What do you guys think about a motorcraft fan motor? I found one for $50. Better then aftermarket for the money?
And is there a different motor for high output or is that just the heater core itself?
Next time the motor stops use your EVTM to start tracking power---it could anything from a simple overheating connection or relay, could be the motor but good to know before digging into all that trim.
Hoping its something simple and easy.
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20151126_14_14_15_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20151126_14_14_15_Pro.jpg" border="0" alt=" photo WP_20151126_14_14_15_Pro.jpg"/></a>
the wires in the connector are orange/red stripe and Orange/black stripe.
All I have right ow for wiring diagrams is my 85 e150 manual.. According to the 85 diagram the orange/blk stripe runs from the blower to the resistor..
Now this may sound silly but was thinking if I had a 12v light socket with pigtail wires on it, I could connect it to the orange/black stripe wire and ground. Once connected I could pull the socket/bulb out between the crowle and hood seam and close the hood.. That way I could see the light as I am driving around. When the fan stops I could see if the light goes out or not...
Over this past summer I was trying to gauge the effectiveness of a heater core coolant shut off valve to lower my non-A/C air flow. Running a thermocouple wire lead from under the hood close to the cabin air intake it had to be taped down so it would stay in place and not flap around while driving. It looked dumb as hell but worked well enough in the short term.
Sadly that quicky test didn't reveal anything useful other than the chuckle it gave me seeing how silly it did look. Can't imagine what others on the highway were thinking.
See if you can't find a dedicated EVTM for your van's exact year---that might be more helpful next electrical issue.
And please let us know how this works out, what you find or do to fix your issue.
I have this one
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/1985%20FORD%20TRUCK%20SHOP%20MANUAL%20BODY%20CHASS IS%20ELECTRICAL%20LIGHT.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/1985%20FORD%20TRUCK%20SHOP%20MANUAL%20BODY%20CHASS IS%20ELECTRICAL%20LIGHT.jpg" border="0" alt=" photo 1985 FORD TRUCK SHOP MANUAL BODY CHASSIS ELECTRICAL LIGHT.jpg"/></a>
I have 3 or 4 diagrams from other haynes manuals that year but they are for Crown Vic, pick up and bronco, as well as one from online,, but none for the 88 e150! None show the relay in the heater circuit nor what the orange wire with a red stripe is for..
The orange with black stripe goes to the heater blower and also bypasses the resistor on high speed.
BTW, The past few days when I have had the blower on, it has been on low speed only and has not cut off.. When I did notice it cutting off, it was on high speed and once off, it lost all speeds.
Something very strange happened though... yesterday I happened to look down on the ground where I park and there was a small plastic baggy that looked like it had been stepped on a few times as it was pretty ragged and dirty... In the baggy was a set of motor brushes!
I paused in writing this to look for them and now I am thinking, where in the heck did I put them, I remember putting them in some place where they wouldn't get thrown away..
My thought is that they are completely unrelated or fell out of the pocket in the engine cover when I took it off.. I don't know if it is serviceable but if I do wind up replacing the motor, I will keep the old motor for when I do find those motor brushes one day! by tht time I will have lost the old motor though
I have this one
Just like socks in the laundry. Why do you have so many unmatched socks, you never threw any away? Its that same little sneaky #*#*# that stole your tools!
