will a 93 cab and 7.3 engine go on a 91 frame?
Received 3,107 Likes
on
YES. but you can not intermix.
But the problem comes in the wiring harness and how they pass thru the cab are COMPLETELY DIFFERENT. You would want a 87-91. (92-97) are different
I have a 91 superduty with a diesel, what I want to do is replace the cab complete and the engine is shot, so I am hoping to find a decent f350 and swap the complete cab/ front assembly and engine. finding a nice 87 to 91 is not so easy as most are pretty worn so I was wondering if there were options for later years as more are available.
on
the newer cab and engine will bolt rite on. the one thing you will have to work around is the front bumper mounts. but that is minor fabrications ot put newer bumper on an older frame. if you find a newer powerstroke truck that will give you the extra power of the powerstroke engine .
on
any cab from 83? to 97 will bolt on the frame. when i said a newer powerstroke setup i was referring to the 94 1/2 to 97 with powerstroke engine. this setup will give you the computerized engine with more power, and all the proper wiring to connect it.
83 to 94 1/2 was IDI engine, 94 1/2 to 97 was direct injected powerstroke engine.
you will need the cab that is related to the engine to make everything work.
the only thing i am not sure about is if the 91 Dana 80 ABS tone ring and pickup will work as a VSS signal for the 92 and newer speedometer setup.
on
classictruckman
16
04-15-2017 02:48 AM
thedieselkid
11-10-2012 08:22 PM
38-72
07-27-2012 03:51 AM
quehele
03-09-2007 12:08 PM
