[QUOTE=DougJ_1997PSD;15828029]So since the truck I may get the front axle from is a 95, do I need to take the t-case too since mine won't work?[/QUOTE
I think what ReBilld is saying is get the yoke if the doner is a 96 or 97 because its what you'll need, if its a pre 96 the yoke wont work for you... Your case is fine to use; its just a pre 96 yoke wont fit it..
I think what ReBilld is saying is get the yoke if the doner is a 96 or 97 because its what you'll need, if its a pre 96 the yoke wont work for you... Your case is fine to use; its just a pre 96 yoke wont fit it..[/QUOTE]
OK, that makes more sense. I was overthinking it as usual.
