Driveshaft Length
Old Nov 25, 2015 | 09:17 PM
coreyallan01's Avatar
coreyallan01
Originally Posted by DougJ_1997PSD
I actually found a 95 D60 I will be looking at soon. I think the ball joints and bigger rotors are better for my applications. I may get a KP if one comes my way but honestly I will go for just about anything at this point. I can't wait to put my new springs in with it.
Where are you located?
I think in another thread I read Md?
ford dana 60 $850
http://winchester.craigslist.org/pts/5302944328.html
A little pricey IMHO..
You could convert this if you could get it for cheeper..
Ford Dana 60 front rear $600
1997 ford f350 powerstroke 4x4 for parts
http://easternshore.craigslist.org/pts/5326808779.html
http://chambersburg.craigslist.org/pts/5324968398.html
F-350 Solid Front Axel $575
http://southjersey.craigslist.org/pts/5294127354.html
Old Nov 26, 2015 | 06:24 AM
Diesel_Brad's Avatar
Diesel_Brad
ford dana 60 $850
ford dana 60
Damit, Just when I go and sell my trailer
Old Nov 26, 2015 | 09:24 AM
DougJ_1997PSD's Avatar
DougJ_1997PSD
Yeah, central MD. This is the listing I found https://baltimore.craigslist.org/pts/5280244318.html
I talked to the guy and he said it was a 4.10 so I'm hoping I can get it with hardware for $300-600.
Old Nov 26, 2015 | 11:08 AM
ReBilld's Avatar
ReBilld
Make sure you get the pitman arm, track bar, track bar bracket, and the u-bolt bracket for the drivers side. All the tire rod and drag link stuff too.
Old Nov 26, 2015 | 11:33 AM
coreyallan01
Just out of curiosity, when I look at the components of that truck it screams 2wd dually at me.. He does know your after a front axle correct?
Old Nov 26, 2015 | 01:16 PM
DougJ_1997PSD
Good call...I just texted him to double check. Happy turkey day to everyone here!
Old Nov 26, 2015 | 01:20 PM
DougJ_1997PSD
He said yes, so I'm in the clear. I didn't even think of that though. I would have been VERY disappointed had it been a 2wd.
Old Nov 26, 2015 | 01:46 PM
coreyallan01
Ok cool; I didnt want to see you go through all the effort for something that was a dud...
Old Nov 26, 2015 | 07:16 PM
Diesel_Brad
I was thinking the same thing
Old Nov 26, 2015 | 09:45 PM
DougJ_1997PSD
That would have been a royal pain. I don't want to derail this thread but I wanted to ask about your boost fooler...how do you make it and is it worth it?
Old Nov 26, 2015 | 09:50 PM
coreyallan01
I think I bought it here.. Not sure if a federal truck would need one.. Ive got splits and a 17 degree hpop.. Do you throw a CEL on overboost? My CEL still comes on but for hpop not boost.. Ive got it mounted neatly on the side of the engine cowl. Is it worth it? Id say yes..
Driven Diesel Overboost Annihilator 99-03 7.3L Ford Powerstroke
Old Nov 27, 2015 | 07:20 PM
DougJ_1997PSD
I think that it may not be a problem since you have a CA truck and I have single shots. I have pulled 30+ psi and never gotten a CEL.
Old Nov 28, 2015 | 12:57 PM
  #28
LeoJr's Avatar
LeoJr
And to your original question...See if you can get the front drive shaft too, even if it needs rebuilding. And for super bonus points the front yoke from the transfer case.
Edited to add: Get the rear lift blocks too unless you have another solution to lift the rear. Many people will tell you to not reuse U-bolts... The 350 may also have an overload leaf and spacer bracket that may be of interest to you. You will need the frame 'ears' that that these settle onto.
Snag sway bar pieces if you can. The clamps on the axle can be tricky to source, but can be fab'd if you are handy. Same thing with the frame end of the sway bar links, front and rear.
Old Nov 28, 2015 | 11:59 PM
  #29
DougJ_1997PSD
I will definitely see what I can scavenge. Thanks!
Old Nov 29, 2015 | 09:11 AM
  #30
ReBilld's Avatar
ReBilld
The yoke from the t-case will only work if the it a '96 or '97 with a 4407 t-case. If the donor truck is a '95 or back, it has a 1356 t-case, and that yoke won't work on the 4407. And good call on the rear blocks and u-bolts! I forgot about those! LOL!
