How to remove door jamb switch?
Old Nov 22, 2015 | 07:26 PM
atikovi's Avatar
atikovi
Drivers side switch on my 2003 E450 won't turn on the dome light when I open the door. Passenger side works fine. How is it removed? Can't get a socket on that nut. Just pry out the plastic housing?
Old Nov 23, 2015 | 07:57 AM
JWA's Avatar
JWA
The front switches simply pop into and out of the jamb---use any kind of panel lifting tool intended for auto upholstery work.
IIRC the switch is much the same as any other similar electrically but differs only in the larger plastic button that mounts it to the body.
Old Nov 23, 2015 | 03:56 PM
atikovi's Avatar
atikovi
Thanks. Pried it out and the wires were off. Connected them back and the light works fine.
Peavey1986
Dec 20, 2015 07:11 PM
borland
34
Jan 7, 2015 10:15 PM
kermmydog
Mar 11, 2013 02:53 PM
dcara
Feb 8, 2010 06:56 PM
west488
Jan 27, 2006 11:52 AM
