Spout leakage
Old Nov 22, 2015 | 01:40 PM
hotrodfeguy's Avatar
hotrodfeguy
Spout leakage
What causes oil coming out of the oil spouts on the injectors? I pulled my VC to re torque my injectors down and I noticed 2 of mine are now leaking oil out the spouts(when warming the engine). Note I did not say the base of the injector.
Old Nov 22, 2015 | 01:42 PM
z31freakify's Avatar
z31freakify
The actual spout or from the solenoid weep hole?
Old Nov 22, 2015 | 01:43 PM
hotrodfeguy
Yes sir that would be it
Old Nov 22, 2015 | 01:51 PM
z31freakify
From what ive seen at work and on my Mule ill say that is normal.
Note I have stage 1's on the Mule with 30k on them and they did it since I installed them
Old Nov 22, 2015 | 02:02 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
When I pulled my valve covers to hot torque my 160/30s, I noted a couple of the injectors were squirting, not weeping, out the weep hole on the downhill side. There should be oil coming out the spout. That is what it is there for. I would add to this question, though:
How much oil should be coming out the little weephole on the manifold side?
Old Nov 22, 2015 | 02:44 PM
z31freakify
Good question. Maybe someone with injector rebuild experience woul shime in.
Old Nov 22, 2015 | 07:42 PM
hotrodfeguy
This is what I was talking about but he has about half what I do.
Old Nov 22, 2015 | 07:53 PM
z31freakify
Thats the spout drains it should have oil comming out, since you said only 2 have oil coming out im assuming your other injectors are worn out. On the opposite side of the injector spout there is a small hole that oil should weep out of.
Old Nov 23, 2015 | 08:01 AM
Tugly's Avatar
Tugly
I have a short bungee cord with plastic hooks (I might have paid a buck for it) - it's blue. I use that for pulling the 42-pin connector out of the way for open-VC running.
Oil out the spout is expected, this is the injector purging the ICP oil it used to fire the fuel into the cylinder. Weeping out the lower holes near the solenoid is normal, but I am unsure what oil shooting out of the weep holes signifies - it may mean nothing.
BRIAN NORCAL
Jul 17, 2018 08:36 AM
Racecar_Dave
Jan 6, 2018 10:47 AM
MONAVIERONJON
May 9, 2017 11:59 AM
MONAVIERONJON
Feb 18, 2010 11:08 PM
WH90
Mar 6, 2009 02:57 PM
