Dana 60 Pinion preload
Old Nov 22, 2015 | 12:01 AM
giorgio.fo's Avatar
giorgio.fo
hi guys,
need help to figure out why i am not able to set the pinion preload to specs.
It was fine last time i checked. the old bearings were shot so i have been using the new bearings to set up the gears.
before taking the carrier to the shop to get my new bearings pressed in had a beautifull 20 ft-lb.
just went to do a final check before installino the pinion oil seal and with the pinion nut at 250ft-lb i get 10 ft-lb!!??!!?
tried to decrease the shims to get more preload but nothing changes. how is that possible?
inspected the bearings... everything looks ok.
any suggestion is very much appreciated..
Ford77Pickup
Feb 10, 2017 05:35 PM
BigTiny460
Mar 26, 2013 08:10 AM
Tomahawk2506
May 9, 2012 11:26 PM
427 fordman
Dec 3, 2011 02:31 PM
MEPR
Jul 18, 2005 07:33 AM
