2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 EB - "lumpy" idle after phaser lockout install
Old Nov 21, 2015 | 09:14 PM
uncleben03's Avatar
uncleben03
I just installed the Livernois cam phaser lockout kit on my wife's 07 EB with about 140k miles. Solved the cam phaser rattling deal. But now, the motor has "lumpy" idle like it might be if there was a racing cam or something in it. There are no DCT's displayed at all. The way I understand how the variable timing worked was the VCT solenoids would regulate oil pressure to the cam phasers. It seems like with the lockout kit installed, a bad VCT would have no impact on timing anymore since the cam phasers are locked out. Am I thinking correctly on that? If not, should I look at VCT's? One of the codes that I had in the DTC history before I re-programmed the computer with the lockout kit tuner was P0345, camshaft position sensor bank 2. That code was cleared and is not present anymore. The motor runs perfectly normal with any amount of throttle applied.
Any thoughts?
Old Nov 22, 2015 | 01:54 AM
Ford'05HG's Avatar
Ford'05HG
Maybe your cams were broken in the more aggressive mode and you locked them in that way.?
How is your gas mileage?
Old Nov 28, 2015 | 08:54 PM
uncleben03's Avatar
uncleben03
After the lockout install it seems like the mileage has gone down about 1 MPG.
Old Dec 16, 2015 | 12:10 AM
Ford'05HG's Avatar
Ford'05HG
If you aren't noticing any issues and can live with the 1 mpg drop, I wouldn't worry about it. I think I would enjoy the new sound too, probably too much. The 5.4 will likely always be my favorite gas V8. I really miss mine.
Old Jan 13, 2016 | 07:08 PM
shawshank927's Avatar
shawshank927
I just added the phasers to my lincoln navigator. I ordered the lock out kit from eBay but i didn't order the programmer. Now my check engine light is on. Can I pay to rent your programmer or do you know where I can purchase a programmer. you can email, text or call
emailblastatlanta@gmail.com or 678 995 3253 thanks
Old Jan 13, 2016 | 07:09 PM
shawshank927
Looking for a Phaser tuner
troy's66customcab
Mar 31, 2011 09:08 PM
shadow_almanza
Jun 5, 2010 07:50 AM
03 Power Smoke
Apr 21, 2008 09:40 AM
tallica2002
Jan 30, 2006 10:16 PM
novadragman2005
Jan 10, 2005 12:51 PM
